A few days ago, I updated my PHP version to 5.4.10 (before 5.4.8 as far as I know). Since then, some widgets and sites don’t load anymore. E.g. the visits by server time, keywords or overview but even pages like Visitors -> Visitor log.
While loading the dashboard, I get the message “Oops… problem during the request, please try again.”, but how can I look for what’s exactly wrong while loading the content?
Can you tell me what version of python you are using?
Is there any error logs you can find for the server that will help us?
Who is the ISP? Is this a VPS type of server or your own stabd alone? what server config do you have?(i mean OS and linux distro) unless its a windows one.
Python is version 2.6.6 on a Linux Debian Squeeze 64-Bit with PHP sources from DotDeb. It’s a dedicated server, which I administrate by myself. Except of this, I have no other problem, especially with PHP.
Neither the server logs (lighttpd) nor the PHP error logs are logging anything.
The only error, which occurs is the following:
[05-Jan-2013 21:23:24 UTC] PHP Fatal error: Nesting level too deep - recursive dependency? in /var/www/piwik/core/View.php on line 44
However, it doesn’t log everytime I view the piwik stats thus I don’t think that this is the main problem, here.
ok the python i know ideally should be 2.7.3 at least so there is one potential issue.
That error could be a regression (see below), any chance you could try the latest beta to see if that fixes the issue? Maybe do the python update first see if that helps then try the beta?
i understand though this beta is quite advanced and stable as far as its been beta for longer than most of teh betas i ve seen. Bottom line i respect your decision.
the link was to show perhaps you need to mention to dev team that this regression has potentially taken place.
I would definitely update the python since you updated the php though.
There is a /tmp folder in the piwik folder that might help here if you delete its contents and try to recreate your widgets.
Normally, I’m using Firefox but tried it now with Google Chrome (Windows) and on my MacBook with Firefox, Chrome and Safari. Problem occurs on every system.
When the widgets dont load, the solution is always to check the server error logs to see the exact error, then search the FAQ for this error to find solution
