Problems after Update to 0.6
After Updating to v 0.6 I get a bunch of errors:
Preparing archive: archive already processed [id = 104]…
Open Flash Chart
JSON Parse Error [Syntax Error]
Error at character 0, line 1:
0: Preparing archive: archive already processed [id = 1
This error comes, when I try to update the archive via shell:
And errors like this one:
Archiving period = year for idsite = 2…
Preparing archive: skipped, archive is before the website was created.
I checked the config-file, everything seems to be ok in there.
Any idea what went wrong?
Greetings,
Joe
see http://dev.piwik.org/trac/ticket/1334#comment:1
Doesnt seem to be the problem, ;logger_message is as it should be in my config.ini.php and global.ini.php.
And I dont get any data for yesterday anymore: only the Message
"SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query"
Greetings,
Joe
can you copy paste your config.ini.php and global.ini.php (without the database section)?
I just installed Piwik completely from the scratch, with a new DB. It worked for about one minute, then the same messages as above…
More precisely: The first archive-update worked, then the same errors as above.
One more detail: on the dashboard I can look at the data before the update without any problems, and piwik is still collecting data (the DB is growing).
Greetings,
Joe
It’s very strange, that your dashboard loads and then widgets say that they couldn’t find the config file?? that is not supposed to be technically possible (unless you delete/rename the config file between the dashboard generation the time the widgets execute)
As nothing seems to help, I reverted to a backup of my entire Website I made two days ago (with Piwik v.0.5). Now everythings works fine again, but the data of the last two days is of course gone…
Joe
Are you using a load balancer for the web server? (Could it be one instance hasn’t mirrored the config directory?)
The MySQL error suggests there’s a connectivity issue between the web server and MySQL server.
In both of these cases, you should probably also consult the sysadmin / hosting provider.
No load balancer.
Piwik 0.5.5 runs perfect as ever now. Somehow I dont dare to update to 0.6 again…
Greetings,
Joe
I have since my update today from vers. 0.5.5 to 0.6.1 the same problems.
Error Messages:
Last visits graph:
Open Flash Chart
0: Preparing archive: archive already processed [id = 21]…<
List of Keywords:
Preparing archive: archive already processed [id = 31]…
Best search engines:
Visits by server time:
Open Flash Chart
0: Preparing archive: archive already processed [id = 31]…
and more like this…
McHunter: we made changes to config/global.ini.php in 0.6; please make sure this file is up-to-date; the log section should contain:
[log]
;possible values for log: screen, database, file
; by default, standard logging/debug messages are hidden from screen
;logger_message[]               = screen
logger_error[]                  = screen
logger_exception[]              = screen
[quote=vipsoft @ May 7 2010, 07:58 PM]McHunter: we made changes to config/global.ini.php in 0.6; please make sure this file is up-to-date; the log section should contain:
[log]
[/quote]
Hi vipsoft
Thank you very much for your quick support.
The “;” in front of the following line in the global.ini:
fixed my problem.
In version 0.5.5:
[log]
; normal messages
and in/for vers. 0.6.1:
[log]
Why ist this not getting fixed automatically bei automatic update? style_emoticons/<#EMO_DIR#>/dry.gif
Thx for the new piwik version.
The error messages are gone but since the update to vers. 0.6.1 there are no visitor counts! - Why?
I don’t know for certain without seeing your database.
At minimum, you’ll have to go to the Settings | Web Sites manager, and set the timezone for your site(s).
Then you may have to delete the archives generated today.
@visoft
thx for your tips
[quote=vipsoft @ May 8 2010, 12:03 AM) <{POST_SNAPBACK}>
Please see the image attachment.
QUOTE (vipsoft @ May 8 2010, 12:03 AM) [<{POST_SNAPBACK}>](index.php?act=findpost&pid=35851)
At minimum, you'll have to go to the Settings | Web Sites manager, and set the timezone for your site(s).
Done
QUOTE (vipsoft @ May 8 2010, 12:03 AM]Then you may have to delete the archives generated today.[/quote] Where do i find these archives (files or db entries?)?
@visoft
Meanwhile I made a new piwik installation with the exitisting database and everything runs perfectly.
The problems (in my case) are thus created by the piwik Auto Update. That happend already with the last three Auto Update releases. So, the next piwik update(s) i will do manually. style_emoticons/<#EMO_DIR#>/wink.gif
Thx for your support.
I tried it once again:
brand new Piwik-Installation, brand-new DB:
same problems like before:
General error: 2013 Lost connection to MySQL server during query | The Piwik configuration file couldn’t be found and you are trying to access a Piwik page etc…
The funny thing about this is, that with a brand new installation the very first archive processing works fine, all further attempts to process the archive produce the errors listed above.
And why does 0.5.5 work on the same server without any problems?
Here are the php-settings:
Directive    Local Value
allow_call_time_pass_reference    Off
allow_url_fopen    On
allow_url_include    Off
always_populate_raw_post_data    Off
arg_separator.input    &
arg_separator.output    &
asp_tags    Off
auto_append_file    no value
auto_globals_jit    On
auto_prepend_file    no value
browscap    no value
default_charset    no value
default_mimetype    text/html
define_syslog_variables    Off
disable_classes    no value
disable_functions    no value
display_errors    Off
display_startup_errors    Off
doc_root    no value
docref_ext    no value
docref_root    no value
enable_dl    Off
error_append_string    no value
error_log    no value
error_prepend_string    no value
error_reporting    6143
expose_php    On
extension_dir    /usr/lib64/php5/extensions
file_uploads    On
highlight.bg    #FFFFFF
highlight.comment    #FF8000
highlight.default    #0000BB
highlight.html    #000000
highlight.keyword    #007700
highlight.string    #DD0000
html_errors    Off
ignore_repeated_errors    Off
ignore_repeated_source    Off
ignore_user_abort    Off
implicit_flush    Off
include_path    .:.:/usr/share/php5:/usr/share/php5/PEAR
log_errors    On
log_errors_max_len    1024
magic_quotes_gpc    Off
magic_quotes_runtime    Off
magic_quotes_sybase    Off
mail.force_extra_parameters    no value
max_execution_time    600
max_input_nesting_level    64
max_input_time    60
memory_limit    512M
open_basedir    /srv/xyz/httpdocs:/tmp
output_buffering    4096
output_handler    no value
post_max_size    50M
precision    14
realpath_cache_size    16K
realpath_cache_ttl    120
register_argc_argv    Off
register_globals    Off
register_long_arrays    Off
report_memleaks    On
report_zend_debug    On
safe_mode    Off
safe_mode_exec_dir    no value
safe_mode_gid    Off
safe_mode_include_dir    no value
sendmail_from    no value
sendmail_path    /usr/sbin/sendmail -t -i
serialize_precision    100
short_open_tag    On
SMTP    localhost
smtp_port    25
sql.safe_mode    Off
suhosin.log.phpscript    0
suhosin.log.phpscript.is_safe    Off
suhosin.log.phpscript.name    no value
suhosin.log.sapi    no value
suhosin.log.script    no value
suhosin.log.script.name    no value
suhosin.log.syslog    no value
suhosin.log.syslog.facility    no value
suhosin.log.syslog.priority    no value
suhosin.log.use-x-forwarded-for    Off
track_errors    Off
unserialize_callback_func    no value
upload_max_filesize    50M
upload_tmp_dir    /tmp
user_dir    no value
variables_order    GPCS
xmlrpc_error_number    0
xmlrpc_errors    Off
y2k_compliance    On
zend.ze1_compatibility_mode    Off
mysql
MySQL Support    enabled
Active Persistent Links     0
Active Links     0
Client API version     5.0.45
MYSQL_MODULE_TYPE     external
MYSQL_SOCKET     /var/lib/mysql/mysql.sock
MYSQL_INCLUDE     #NAME?
MYSQL_LIBS     #NAME?
mysql.allow_persistent    Off
mysql.connect_timeout    60
mysql.default_host    no value
mysql.default_password    no value
mysql.default_port    no value
mysql.default_socket    no value
mysql.default_user    no value
mysql.max_links    Unlimited
mysql.max_persistent    Unlimited
mysql.trace_mode    Off
Greetings,
Joe
Same problem after installing 0.6.2.
SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query etc…
0.5.5 still works fine.
Dont know what to do anymore…
Greetings,
Joe
Found this in the mysqld.log:
thd=0x11c5f00
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong...
Cannot determine thread, fp=0x422e0fe0, backtrace may not be correct.
Bogus stack limit or frame pointer, fp=0x422e0fe0, stack_bottom=0x422e0000, thread_stack=262144, aborting backtrace.
Trying to get some variables.
Some pointers may be invalid and cause the dump to abort...
thd->query at 0x1207040 = SELECT idarchive, value, name, date1 as startDate
                                                FROM piwik_archive_numeric_2010_05
                                                WHERE idsite = '1'
                                                        AND date1 = '2010-05-29'
                                                        AND date2 = '2010-05-29'
                                                        AND period = '1'
                                                        AND ( (name = 'done' AND value = 1)
        OR (name = 'done' AND value = 3)
        OR name = 'nb_visits')
                                                         AND ts_archived >= '2010-05-29 10:31:22'
                                                ORDER BY ts_archived DESC
thd->thread_id=1
The manual page at http://www.mysql.com/doc/en/Crashing.html contains
information that should help you find out what is causing the crash.
Greetings,
Joe
