I can’t paste it completely, because i can’t get to the end of the lines. They are hidden behind the layers. Couldn’t find it in the HTML source either.
Seems to be a database login problem, but I was able to use Piwik normally before the update and haven’t changed users in the database.
This is what I could get:
SQLSTATE[42000]: Syntax error or access violation: 1044 Access denied for user ‘piwik’@‘localhost’ to database ‘piwik’
Go to Piwik
Login
Backtrace:
#0 /var/www/piwik/piwik/core/PluginsFunctions/Sql.php(51): Zend_Db_Adapter_Pdo_Abstract->exec(‘LOCK TABLES piw…’)
#1 /var/www/piwik/piwik/core/PluginsFunctions/Sql.php(205): Piwik_Sql::exec(‘LOCK TABLES piw…’)
#2 /var/www/piwik/piwik/core/PluginsFunctions/Sql.php(359): Piwik_Sql::lockTables(‘piwik_archive_n…’, ‘piwik_archive_n…’)
#3 /var/www/piwik/piwik/core/ArchiveProcessing.php(688): Piwik_LockTables(‘piwik_archive_n…’, ‘piwik_archive_n…’)
#4 /var/www/piwik/piwik/core/ArchiveProcessing.php(533): Piwik_ArchiveProcessing->loadNextIdarchive()
#5 /var/www/piwik/piwik/core/ArchiveProcessing.php(472): Piwik_ArchiveProcessing->initCompute()
#6 /var/www/piwik/piwik/core/Archive/Single.php(226): Piwik_ArchiveProcessing->launchArchiving()
#7 /var/www/piwik/piwik/core/Archive/Array/IndexedByDate.php(90): Piwik_Archive_Single->prepareArchive()
#8 /var/www/piwik/piwik/plugins/VisitsSummary/API.php(88): Piwik_Archive_Array_IndexedByDate->getDataTableFromNumeric(Array)
#9 [internal function]: Piwik_VisitsSummary_API->get(‘2’, ‘day’, ‘2012-05-02,2012…’, false, ‘nb_visits’)
#10 /var/www/piwik/piwik/core/API/Proxy.php(190): call_user_func_array(Array, Array)
#11 /var/www/piwik/piwik/plugins/API/API.php(986): Piwik_API_Proxy->call(‘Piwik_VisitsSum…’, ‘get’, Array)
#12 [internal function]: Piwik_API_API->get(‘2’, ‘day’, ‘2012-05-02,2012…’, false, ‘nb_visits’)
#13 /var/www/piwik/piwik/core/API/Proxy.php(190): call_user_func_array(Array, Array)
#14 /var/www/piwik/piwik/core/API/Request.php(128): Piwik_API_Proxy->call(‘Piwik_API_API’, ‘get’, Array)
#15 /var/www/piwik/piwik/core/ViewDataTable.php(421): Piwik_API_Request->process()
#16 /var/www/piwik/piwik/core/ViewDataTable/GenerateGraphData/ChartEvolution.php(109): Piwik_ViewDataTable->loadDataTableFromAPI()
#17 /var/www/piwik/piwik/core/ViewDataTable/GenerateGraphData.php(181): Piwik_ViewDataTable_GenerateGraphData_ChartEvolution->loadDataTableFromAPI()
#18 /var/www/piwik/piwik/core/Controller.php(247): Piwik_ViewDataTable_GenerateGraphData->main()
#19 /var/www/piwik/piwik/plugins/VisitsSummary/Controller.php(78): Piwik_Controller->getLastUnitGraphAcrossPlugins(‘VisitsSummary’, ‘getEvolutionGra…’, Array, Array, ‘Dies ist eine ?..’)
#20 [internal function]: Piwik_VisitsSummary_Controller->getEvolutionGraph()
#21 /var/www/piwik/piwik/core/FrontController.php(138): call_user_func_array(Array, Array)
#22 /var/www/piwik/piwik/core/FrontController.php(159): Piwik_FrontController->dispatch(‘VisitsSummary’, ‘getEvolutionGra…’, Array)
#23 /var/www/piwik/piwik/core/ViewDataTable/GenerateGraphHTML.php(170): Piwik_FrontController->fetchDispatch(‘VisitsSummary’, ‘getEvolutionGra…’, Array)
#24 /var/www/piwik/piwik/core/ViewDataTable/GenerateGraphHTML.php(125): Piwik_ViewDataTable_GenerateGraphHTML->getGraphData()
#25 /var/www/piwik/piwik/core/ViewDataTable/GenerateGraphHTML.php(109): Piwik_ViewDataTable_GenerateGraphHTML->buildView()
#26 /var/www/piwik/piwik/core/Controller.php(247): Piwik_ViewDataTable_GenerateGraphHTML->main()
#27 /var/www/piwik/piwik/plugins/VisitsSummary/Controller.php(78): Piwik_Controller->getLastUnitGraphAcrossPlugins(‘VisitsSummary’, ‘getEvolutionGra…’, Array, Array, ‘Dies ist eine ?..’)
#28 /var/www/piwik/piwik/plugins/VisitsSummary/Controller.php(23): Piwik_VisitsSummary_Controller->getEvolutionGraph(true, Array)
#29 [internal function]: Piwik_VisitsSummary_Controller->index()
#30 /var/www/piwik/piwik/core/FrontController.php(138): call_user_func_array(Array, Array)
#31 /var/www/piwik/piwik/index.php(53): Piwik_FrontController->dispatch()
#32 {main}
