Well then post the full error message. The error posted in the first post is only related to the lock tables priviledge.
Since my error messages are basically the same … I thought I would not have to repost them.
Do you mean you get the
SQLSTATE[42000]: Syntax error or access violation: 1044 Access denied for user ‘piwik’@‘localhost’ to database ‘piwik’ ?
them please post again your FULL error message
VISITORS BY SERVERTIME
SQLSTATE[42000]: Syntax error or access violation: 1044 Access denied for user ‘piwik_user’@‘localhost’ to database ‘my_crazy_database’
Backtrace:
#0 /home/path/to/piwik/core/PluginsFunctions/Sql.php(51): Zend_Db_Adapter_Pdo_Abstract->exec(‘LOCK TABLES piw…’)
#1 /home/path/to/piwik/core/PluginsFunctions/Sql.php(205): Piwik_Sql::exec(‘LOCK TABLES piw…’)
#2 /home/path/to/piwik/core/PluginsFunctions/Sql.php(359): Piwik_Sql::lockTables(‘piwik_archive_n…’, ‘piwik_archive_n…’)
#3 /home/path/to/piwik/core/ArchiveProcessing.php(688): Piwik_LockTables(‘piwik_archive_n…’, ‘piwik_archive_n…’)
#4 /home/path/to/piwik/core/ArchiveProcessing.php(533): Piwik_ArchiveProcessing->loadNextIdarchive()
#5 /home/path/to/piwik/core/ArchiveProcessing/Period.php(230): Piwik_ArchiveProcessing->initCompute()
#6 /home/path/to/piwik/core/ArchiveProcessing.php(472): Piwik_ArchiveProcessing_Period->initCompute()
#7 /home/path/to/piwik/core/Archive/Single.php(226): Piwik_ArchiveProcessing->launchArchiving()
#8 /home/path/to/piwik/core/Archive/Single.php(256): Piwik_Archive_Single->prepareArchive()
#9 /home/path/to/piwik/core/Archive/Single.php(514): Piwik_Archive_Single->get(‘VisitTime_serve…’, ‘blob’, NULL)
#10 /home/path/to/piwik/plugins/VisitTime/API.php(34): Piwik_Archive_Single->getDataTable(‘VisitTime_serve…’)
#11 /home/path/to/piwik/plugins/VisitTime/API.php(48): Piwik_VisitTime_API->getDataTable(‘VisitTime_serve…’, ‘1’, ‘range’, ‘last30’, false)
#12 [internal function]: Piwik_VisitTime_API->getVisitInformationPerServerTime(‘1’, ‘range’, ‘last30’, false, ‘1’)
#13 /home/path/to/piwik/core/API/Proxy.php(190): call_user_func_array(Array, Array)
#14 /home/path/to/piwik/core/API/Request.php(128): Piwik_API_Proxy->call(‘Piwik_VisitTime…’, ‘getVisitInforma…’, Array)
#15 /home/path/to/piwik/core/ViewDataTable.php(421): Piwik_API_Request->process()
#16 /home/path/to/piwik/core/ViewDataTable/GenerateGraphData.php(181): Piwik_ViewDataTable->loadDataTableFromAPI()
#17 /home/path/to/piwik/core/Controller.php(152): Piwik_ViewDataTable_GenerateGraphData->main()
#18 /home/path/to/piwik/plugins/VisitTime/Controller.php(35): Piwik_Controller->renderView(Object(Piwik_ViewDataTable_GenerateGraphData_ChartVerticalBar), false)
#19 [internal function]: Piwik_VisitTime_Controller->getVisitInformationPerServerTime()
#20 /home/path/to/piwik/core/FrontController.php(138): call_user_func_array(Array, Array)
#21 /home/path/to/piwik/core/FrontController.php(159): Piwik_FrontController->dispatch(‘VisitTime’, ‘getVisitInforma…’, Array)
#22 /home/path/to/piwik/core/ViewDataTable/GenerateGraphHTML.php(170): Piwik_FrontController->fetchDispatch(‘VisitTime’, ‘getVisitInforma…’, Array)
#23 /home/path/to/piwik/core/ViewDataTable/GenerateGraphHTML.php(125): Piwik_ViewDataTable_GenerateGraphHTML->getGraphData()
#24 /home/path/to/piwik/core/ViewDataTable/GenerateGraphHTML.php(109): Piwik_ViewDataTable_GenerateGraphHTML->buildView()
#25 /home/path/to/piwik/core/Controller.php(152): Piwik_ViewDataTable_GenerateGraphHTML->main()
#26 /home/path/to/piwik/plugins/VisitTime/Controller.php(35): Piwik_Controller->renderView(Object(Piwik_ViewDataTable_GenerateGraphHTML_ChartVerticalBar), false)
#27 [internal function]: Piwik_VisitTime_Controller->getVisitInformationPerServerTime()
#28 /home/path/to/piwik/core/FrontController.php(138): call_user_func_array(Array, Array)
#29 /home/path/to/piwik/index.php(53): Piwik_FrontController->dispatch()
#30 {main}
LAST VISITS GRAPH
Backtrace:
#5 /home/path/to/piwik/core/ArchiveProcessing.php(472): Piwik_ArchiveProcessing->initCompute()
#6 /home/path/to/piwik/core/Archive/Single.php(226): Piwik_ArchiveProcessing->launchArchiving()
#7 /home/path/to/piwik/core/Archive/Array/IndexedByDate.php(90): Piwik_Archive_Single->prepareArchive()
#8 /home/path/to/piwik/plugins/VisitsSummary/API.php(88): Piwik_Archive_Array_IndexedByDate->getDataTableFromNumeric(Array)
#9 [internal function]: Piwik_VisitsSummary_API->get(‘1’, ‘day’, ‘last30’, false, ‘nb_visits’)
#10 /home/path/to/piwik/core/API/Proxy.php(190): call_user_func_array(Array, Array)
#11 /home/path/to/piwik/plugins/API/API.php(986): Piwik_API_Proxy->call(‘Piwik_VisitsSum…’, ‘get’, Array)
#12 [internal function]: Piwik_API_API->get(‘1’, ‘day’, ‘last30’, false, ‘nb_visits’)
#14 /home/path/to/piwik/core/API/Request.php(128): Piwik_API_Proxy->call(‘Piwik_API_API’, ‘get’, Array)
#16 /home/path/to/piwik/core/ViewDataTable/GenerateGraphData/ChartEvolution.php(109): Piwik_ViewDataTable->loadDataTableFromAPI()
#17 /home/path/to/piwik/core/ViewDataTable/GenerateGraphData.php(181): Piwik_ViewDataTable_GenerateGraphData_ChartEvolution->loadDataTableFromAPI()
#18 /home/path/to/piwik/core/Controller.php(247): Piwik_ViewDataTable_GenerateGraphData->main()
#19 /home/path/to/piwik/plugins/VisitsSummary/Controller.php(78): Piwik_Controller->getLastUnitGraphAcrossPlugins(‘VisitsSummary’, ‘getEvolutionGra…’, Array, Array, ‘This is an over…’)
#20 [internal function]: Piwik_VisitsSummary_Controller->getEvolutionGraph()
#21 /home/path/to/piwik/core/FrontController.php(138): call_user_func_array(Array, Array)
#22 /home/path/to/piwik/core/FrontController.php(159): Piwik_FrontController->dispatch(‘VisitsSummary’, ‘getEvolutionGra…’, Array)
#23 /home/path/to/piwik/core/ViewDataTable/GenerateGraphHTML.php(170): Piwik_FrontController->fetchDispatch(‘VisitsSummary’, ‘getEvolutionGra…’, Array)
#24 /home/path/to/piwik/core/ViewDataTable/GenerateGraphHTML.php(125): Piwik_ViewDataTable_GenerateGraphHTML->getGraphData()
#25 /home/path/to/piwik/core/ViewDataTable/GenerateGraphHTML.php(109): Piwik_ViewDataTable_GenerateGraphHTML->buildView()
#26 /home/path/to/piwik/core/Controller.php(247): Piwik_ViewDataTable_GenerateGraphHTML->main()
#27 /home/path/to/piwik/plugins/VisitsSummary/Controller.php(78): Piwik_Controller->getLastUnitGraphAcrossPlugins(‘VisitsSummary’, ‘getEvolutionGra…’, Array, Array, ‘This is an over…’)
#28 [internal function]: Piwik_VisitsSummary_Controller->getEvolutionGraph()
#29 /home/path/to/piwik/core/FrontController.php(138): call_user_func_array(Array, Array)
#30 /home/path/to/piwik/index.php(53): Piwik_FrontController->dispatch()
#31 {main}
GRAPH RETURNING VISITS
Backtrace:
#8 /home/path/to/piwik/plugins/VisitFrequency/API.php(81): Piwik_Archive_Array_IndexedByDate->getDataTableFromNumeric(Array)
#9 [internal function]: Piwik_VisitFrequency_API->get(‘1’, ‘day’, ‘last30’, false, ‘nb_visits_retur…’)
#11 /home/path/to/piwik/plugins/API/API.php(986): Piwik_API_Proxy->call(‘Piwik_VisitFreq…’, ‘get’, Array)
#12 [internal function]: Piwik_API_API->get(‘1’, ‘day’, ‘last30’, false, ‘nb_visits_retur…’)
#19 /home/path/to/piwik/plugins/VisitFrequency/Controller.php(75): Piwik_Controller->getLastUnitGraphAcrossPlugins(‘VisitFrequency’, ‘getEvolutionGra…’, Array, Array, ‘This is an over…’)
#20 [internal function]: Piwik_VisitFrequency_Controller->getEvolutionGraph()
#22 /home/path/to/piwik/core/FrontController.php(159): Piwik_FrontController->dispatch(‘VisitFrequency’, ‘getEvolutionGra…’, Array)
#23 /home/path/to/piwik/core/ViewDataTable/GenerateGraphHTML.php(170): Piwik_FrontController->fetchDispatch(‘VisitFrequency’, ‘getEvolutionGra…’, Array)
#27 /home/path/to/piwik/plugins/VisitFrequency/Controller.php(75): Piwik_Controller->getLastUnitGraphAcrossPlugins(‘VisitFrequency’, ‘getEvolutionGra…’, Array, Array, ‘This is an over…’)
#28 [internal function]: Piwik_VisitFrequency_Controller->getEvolutionGraph()
#31 {main}
FREQUENCY OVERVIEW
Backtrace:
#9 /home/path/to/piwik/core/Archive/Single.php(446): Piwik_Archive_Single->get(‘nb_visits_retur…’, ‘numeric’)
#10 /home/path/to/piwik/core/Archive/Single.php(489): Piwik_Archive_Single->getNumeric(‘nb_visits_retur…’)
#11 /home/path/to/piwik/plugins/VisitFrequency/API.php(81): Piwik_Archive_Single->getDataTableFromNumeric(Array)
#12 [internal function]: Piwik_VisitFrequency_API->get(‘1’, ‘range’, ‘last30’, false, false)
#14 /home/path/to/piwik/core/API/Request.php(128): Piwik_API_Proxy->call(‘Piwik_VisitFreq…’, ‘get’, Array)
#15 /home/path/to/piwik/plugins/VisitFrequency/Controller.php(104): Piwik_API_Request->process()
#16 /home/path/to/piwik/plugins/VisitFrequency/Controller.php(88): Piwik_VisitFrequency_Controller->getSummary()
#17 /home/path/to/piwik/plugins/VisitFrequency/Controller.php(30): Piwik_VisitFrequency_Controller->setSparklinesAndNumbers(Object(Piwik_View))
#18 [internal function]: Piwik_VisitFrequency_Controller->getSparklines()
#19 /home/path/to/piwik/core/FrontController.php(138): call_user_func_array(Array, Array)
#20 /home/path/to/piwik/index.php(53): Piwik_FrontController->dispatch()
#21 {main}
Solution: Please grant your database user the permission to LOCK tables, using phpMyAdmin or asking your webhost
This is a new requirement in Piwik 1.8 and we forgot to add a test to warn users about it.
I already have granted that database user the database specific privileges including LOCK TABLES …
In phpmyadmin priviledges for a user can be changed in 2 ways from what I see …
GLOBAL priviledges - which sounds to me as this would effect all databased the users is making use of
Database-specific privileges
Initially I did grants the LOCK TABLES prevailed specifically to the PIWIK database: problem remained
Now I tested and did grant the LOCK TABLES privilege GLOBALLY (for all databases of this user) and the describe problem disappeared …
that are my 5 cent …
OK,
it’s fixed now for me, thanks for the help.
I had to give the LOCK privilege globally AND
had to delete my config.ini.php
Without deleteing the config file, i still got the error about not being able to authenticate.
I am unsure why, because my pw didn’t change.
After a new installation with the wizard, keeping my old data tables, everything works fine now.
After the first login i was presented an update to 1.8.1 which installed without problems.
WE are also considering in a new version NOT require the LOCK privilege, see ticket: Piwik should not require mysql LOCK privilege so more users can enjoy Free Web Analytics! · Issue #3204 · matomo-org/matomo · GitHub
please post a comment in this ticket if your web host does not allow LOCK privilege
