Match/ Regex expression for funnels
Hello :slight_smile:
I am just starting out with Matomo, hope this question is not just a feature request.
When creating a funnel of a goal, I would like to check the event name with a regex? Isn’t that possible, although it’s possible for the goal matching?
Thank you in advance for your time
Hi Sofia,
It is not possible to use regex with funnel steps. You could use an event that is triggered by some logic on your side to trigger the step.
Thanks,
@Jason_1282 I just came across this answer and I am confused. There is an option to use url regex in funnels steps right? I can’t for the life of me get this to work either, but the option is there and I am pretty sure I have got the pattern right by now
Hi Japhy,
If you validate the step in the funnel step validator, does the step go green?
Thanks,
No it’s not and that’s weird because if I use the same pattern as a goal it does work. And as far as I know this is valid regex ^https://domain.com/[a-z]+$
In the end I got it working by using event categories as steps
on a sidenote: I am slightly color blind and on certain screens these colors are really hard to tell apart for me.
Regex is now supported for URL
