Japhy
(Japhy)
1
The url’s are
https://www.domain.com/category/item
(always https, always www, never trailing slash
Basically I would like the goal conversion to be any page visit on https://www.domain.com/categorie/item (not a specific category and item but any!)
One of the steps in funnel would be
https://www.domain.com/category/ (any category)
Because there are many categories and items involved I can only do the with regex, shouldn’t be too difficult but I lack regex knowledge altogether:)
A bit of help would be much appreciated.
Japhy
(Japhy)
2
To follow up, this should do the trick:
^https://domain\.com/[a-z]+$
^https://domain\.com/.+/.+$
However, one thing: if I test both patterns as goals they both work fine, so both seem valid.
But if I use this as a goal
And this as the required step in the funnel
The latter does not work (breaks the funnel). Which is weird because the pattern worked as expected when I use it as a goal
A screenshot to illustrate? Anyone have a suggestion? Would be very welcome, driving me nuts.
@Japhy, did you get a solution on your issue?
