I’m unable to get the Auto-Archiving cron to work… It’s not running, while other crons are running without any issues.
Tried running the cron via crontab -e (user) and nano /etc/crontab (root).
The cron settings:
crontab -e
5 * * * * /usr/local/bin/php /var/www/html/console core:archive --url=https://website.com/ > var/www/logs/cron.log 2>&1
# empty line
nano /etc/crontab
5 * * * * root /usr/local/bin/php /var/www/html/console core:archive --url=https://website.com/ > var/www/logs/cron.log 2>&1
# empty line
Running the command manually works fine:
INFO [2022-04-07 12:01:37] 2966 ---------------------------
INFO [2022-04-07 12:01:37] 2966 INIT
INFO [2022-04-07 12:01:37] 2966 Running Matomo 4.8.0 as Super User
INFO [2022-04-07 12:01:37] 2966 NOTES
Hopefully someone is able to help
