I’d like to use Piwik with Wordpress but it doesn’t work.
I have access to the piwik interface but can’t link piwik to the wordpress.
Here’s the script test:
`WP-Piwik 1.0.14
Mode: http
Test 1/3: global.getPiwikVersion
bool(false)
array(2) {
[0]=>
string(388) "HTTP/1.1 503 Service Unavailable
Server: squid/3.3.8
Mime-Version: 1.0
Date: Tue, 07 Mar 2017 12:47:18 GMT
Content-Type: text/html
Content-Length: 3407
X-Squid-Error: ERR_CONNECT_FAIL 111
Vary: Accept-Language
Content-Language: en
X-Cache: MISS from proxy02.infra.p
X-Cache-Lookup: MISS from proxy02.infra.p:81
Via: 1.1 proxy02.infra.p (squid/3.3.8)
Connection: keep-alive
[1]=>
string(161) "http://methodoc.ina.fr/analytics/index.php/?module=API&method=API.getBulkRequest&format=json&urls[0]=method%3DAPI.getPiwikVersion%26idSite%3Dn%2Fa&token_auth=..."
Test 2/3: SitesManager.getSitesWithAtLeastViewAccess
bool(false)
array(2) {
[0]=>
Server: squid/3.3.8
Mime-Version: 1.0
X-Cache: MISS from proxy01.infra.p
X-Cache-Lookup: MISS from proxy01.infra.p:81
Via: 1.1 proxy01.infra.p (squid/3.3.8)
[1]=>
string(238) "http://methodoc.ina.fr/analytics/index.php/?module=API&method=API.getBulkRequest&format=json&urls[0]=method%3DAPI.getPiwikVersion%26idSite%3Dn%2Fa&urls[1]=method%3DSitesManager.getSitesWithAtLeastViewAccess%26idSite%3Dn%2Fa&token_auth=..."
Test 3/3: SitesManager.getSitesIdFromSiteUrl
bool(false)
array(2) {
[0]=>
Server: squid/3.3.8
Mime-Version: 1.0
[1]=>
string(344) "http://methodoc.ina.fr/analytics/index.php/?module=API&method=API.getBulkRequest&format=json&urls[0]=method%3DAPI.getPiwikVersion%26idSite%3Dn%2Fa&urls[1]=method%3DSitesManager.getSitesWithAtLeastViewAccess%26idSite%3Dn%2Fa&urls[2]=method%3DSitesManager.getSitesIdFromSiteUrl%26idSite%3Dn%2Fa%26url%3Dhttp%3A%2F%2Fmethodoc.ina.fr&token_auth=..."
array(2) {
["global_settings"]=>
array(59) {
["revision"]=>
string(10) "2016120301"
["last_settings_update"]=>
string(10) "1488890819"
["piwik_mode"]=>
string(4) "http"
["piwik_url"]=>
string(43) "http://methodoc.ina.fr/analytics/index.php/"
["piwik_path"]=>
string(33) "http://methodoc.ina.fr/analytics/"
["piwik_user"]=>
string(0) ""
["piwik_token"]=>
string(3) "set"
["auto_site_config"]=>
string(1) "1"
["default_date"]=>
string(9) "yesterday"
["stats_seo"]=>
string(1) "0"
["dashboard_widget"]=>
string(6) "last30"
["dashboard_chart"]=>
string(1) "0"
["dashboard_seo"]=>
string(1) "0"
["toolbar"]=>
string(1) "0"
["capability_read_stats"]=>
array(6) {
["administrator"]=>
string(1) "1"
["editor"]=>
string(1) "0"
["author"]=>
string(1) "0"
["contributor"]=>
string(1) "0"
["subscriber"]=>
string(1) "0"
["ai1ec_event_assistant"]=>
string(1) "0"
["perpost_stats"]=>
string(1) "0"
["plugin_display_name"]=>
string(8) "WP-Piwik"
["piwik_shortcut"]=>
string(1) "0"
["shortcodes"]=>
string(1) "0"
["track_mode"]=>
string(8) "disabled"
["track_codeposition"]=>
string(6) "footer"
["track_noscript"]=>
string(1) "0"
["track_nojavascript"]=>
string(1) "0"
["proxy_url"]=>
string(0) ""
["track_content"]=>
["track_search"]=>
string(1) "0"
["track_404"]=>
string(1) "0"
["add_post_annotations"]=>
string(1) "0"
["add_customvars_box"]=>
string(1) "0"
["add_download_extensions"]=>
string(0) ""
["set_download_extensions"]=>
string(0) ""
["disable_cookies"]=>
string(1) "0"
["limit_cookies"]=>
string(1) "0"
["limit_cookies_visitor"]=>
string(8) "34186669"
["limit_cookies_session"]=>
string(4) "1800"
["limit_cookies_referral"]=>
string(8) "15778463"
["track_admin"]=>
string(1) "0"
["capability_stealth"]=>
array(0) {
["track_across"]=>
string(1) "0"
["track_across_alias"]=>
string(1) "0"
["track_feed"]=>
string(1) "0"
["track_feed_addcampaign"]=>
string(1) "0"
["track_feed_campaign"]=>
string(4) "feed"
["track_heartbeat"]=>
string(1) "0"
["track_user_id"]=>
["cache"]=>
string(1) "1"
["http_connection"]=>
string(4) "curl"
["http_method"]=>
string(4) "post"
["disable_timelimit"]=>
string(1) "0"
["connection_timeout"]=>
string(1) "5"
["disable_ssl_verify"]=>
string(1) "0"
["disable_ssl_verify_host"]=>
string(1) "0"
["piwik_useragent"]=>
string(3) "php"
["piwik_useragent_string"]=>
["track_datacfasync"]=>
string(1) "0"
["track_cdnurl"]=>
string(0) ""
["track_cdnurlssl"]=>
string(0) ""
["force_protocol"]=>
string(4) "http"
["update_notice"]=>
string(7) "enabled"
["settings"]=>
array(6) {
["name"]=>
string(0) ""
["site_id"]=>
string(3) "n/a"
["noscript_code"]=>
string(0) ""
["tracking_code"]=>
string(0) ""
["last_tracking_code_update"]=>
string(1) "0"
["dashboard_revision"]=>
string(1) "0"
I tried the url http://methodoc.ina.fr/analytics/index.php/?module=API&method=API.getBulkRequest&format=json&urls[0]=method%3DAPI.getPiwikVersion%26idSite%3Dn%2Fa&token_auth=
with the token in firefox and got a white page with [“3.0.2”] in it.
Any ideas?
