I installed WP-Matomo and & Matomo Analytics
i added tracking code js to header.php theme
i try to connect WP-Piwik but i have an error
WP-Matomo 1.0.22 was not able to connect to Matomo using your configuration. During connection the following error occured: Could not resolve host: https
If you select Cloud-Hosted, then you need to only enter your Matomo subdomain.
So if you are using https://someexample.matomo.cloud, then you need to enter “someexample” into that form. (In your case it tries to access https://https://someexample.matomo.cloud.matomo.cloud which of course fails).
thanks its works
do i need to add tracking code to all pages?
if i want to track all the pages
what i need to do to start tracking and see which page tracked?
