First question is easy I think. Am I correct that running the Piwik WP plugin obviates the need to past the little Java script into every page so long as I configure the website number correctly? All my webs are Wordpress.
Now for the more difficult question. I had Piwik installed and seemingly working a few weeks ago, but when I went to look at my traffic last night the site was “broken” while before it had shown all sorts of information, albeit with little data since this was a new install. As my site is very new, and loss of data is no big deal, I nuked the entire setup and dropped the SQL tables to start over. I downloaded a fresh copy of the latest software and installed it. The install seemed to go fine and proceeded with no errors. I gave Piwik has its own subdomain and SQL database.
However, after the reinstall I have the same dashboard appearance issues (no data, no graphs, no anything) and when I try to add a web site I get nothing when I hit the green plus sign. Also there is no data entry field for default time zone or currency.
I have found these threads in which similar issues were reported (although it is not clear what I need to do fix it, which is why I am asking again!).
http://forum.piwik.org/read.php?2,44521
This one related to a white listing issue with HostGator and a mod_security setting. Do I need to open a ticket?
http://forum.piwik.org/read.php?2,31121
That one was less clear, but the symptoms are common.
When I try to use Piwik I get the little yellow warning triangle in IE8 with the following error messages:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; Trident/4.0; BTRS35926)
Timestamp: Fri, 17 Jun 2011 18:37:09 UTC
Message: Syntax error
Line: 136
Char: 295
Code: 0
URI: http://piwik.casciainc.com/index.php?module=Proxy&action=getJs&cb=f68951a9d3efd207df9a0b989aa6e1e2
Message: Object expected
Line: 98
Char: 2
Code: 0
URI: http://piwik.casciainc.com/index.php?module=SitesManager&action=index&idSite=1&period=day&date=yesterday
Message: ‘SitesManager’ is undefined
Line: 146
Char: 1
Code: 0
Line: 39
Char: 517
Code: 0
URI: http://piwik.casciainc.com/index.php?module=Proxy&action=getPieHtc
Am I missed a file in the installation package? I uploaded this several ways (Filezilla, FireFTP, and the zip to the server and unzipped from there) with identical results. At this point I am at a loss for what to do next.
