sh /srv/www/vhosts/xyz.com/httpdocs/piwik/misc/cron/archive.sh > /dev/null
it takes ages processing the archive and I get strange outputs like this one:
Can´t be the encoding. Didn´t change it, and the same happens on three different PCs…
I managed to copy a liitle bit of the output from Putty: http://pastebin.com/MMYMcRuZ
I already tried to delete the archives and start a rebuild, doesn´t help.
I forgot to mention one thing: Recently Piwik tried to send me a 2.5gigabyte mail:
This is the beginning of that mail, had to delete it from the server. http://pastebin.com/Efu2rnCv
Thanks for the report. At least, in the next version, the error message will be a lot smaller if there is a problem, making it easier to see the message.
i’m actually facing a similar problem since the update to Piwik 1.4.
I was also using the cron job, but the shell script call with the cron job puts out around 8-10MB of data. As Plesk is sending an eMail every time a cronjob is done, i was receiving all this rubbish output as a 10MB eMail every 30 minutes.
I needed to deactivate the cronjob … any suggestions for a hotfix of this are highly appreciated.
Thanks,
Marco
EDIT: I traced the output in a text file and also found the error message: The last Plesk update seems to have activated the safe_mode in the php.ini. After changing it to “off”, the problem is gone. Thanks for the hints!
