I had to move all my websites to a larger server and decided to move piwik to a different domain name. I follow the instructions via the piwik faqs and everything work fine transferring the database uploading the old piwik folder and modifying the config file. Everything worked for a couple weeks but after a major glitch in joomla I deleted the all the file and folders in the webspace and reinstall everything and uploaded everything again BUT this time none of the websites are being tracked.
So I started over deleted everything and tried it again like I did the first time; transferring the database uploading the old piwik folder and modifying the config file. But still not tracking any of the domains.
Not sure what changed but I need to figure it out.
Can you check if there are any .htaccess files lying around that may block the request? I thing the error log of your webserver should tell you why he responds with a Forbidden.
