Website Works Fine on PC but Not on Android – Need Help
Hi everyone,
I’m facing a strange issue with my website and I’m hoping someone here can help.
My website works perfectly on PC/laptop browsers, but when I try to open it on Android devices, it does not work properly. Sometimes the site doesn’t load at all, and other times it loads but features like menus, buttons, or pages don’t respond correctly.
Here are a few details:
Website is built on WordPress
Desktop (Windows / PC browsers): No issues
Android phones (multiple devices tested): Site fails or behaves abnormally
Other websites work fine on the same Android phones
No major errors visible on PC
I’ve already checked:
Theme and plugins (everything updated)
Cache and CDN
Mobile responsiveness settings
Could this be related to:
Android WebView?
JavaScript or CSS conflicts?
Theme or plugin compatibility with Android?
Server or hosting configuration?
If anyone has faced a similar issue or knows how to debug WordPress websites specifically for Android devices, I’d really appreciate your guidance.
Thanks in advance for your help!
Check HTML: https://validator.w3.org/
Check CSS: https://jigsaw.w3.org/css-validator/
Check JavaScript: Browser Console. (Desktop)
Check JavaScript functions Browser compatibility: https://caniuse.com/?search=parseInt
Use a default Wordpress installation. Then install Theme. Then installt Plugins. Make everytime a check.
I’d start by testing the site in Chrome on Android with an incognito window and checking the browser console for JavaScript errors. If menus and buttons fail, a plugin or script conflict would be one of the first things I’d check. It may also help to temporarily switch to a default WordPress theme and see if the issue remains.
I’d test the site with Chrome DevTools using Android device emulation and check the console for JavaScript errors. Also try temporarily disabling optimization/minification plugins, since broken or delayed JS is a common cause when menus and buttons fail only on mobile.
I would start by testing the site on Android Chrome with JavaScript errors and network requests visible through remote debugging. Temporarily disable plugins one by one, especially optimization or caching plugins, and check whether the issue disappears. If it works on a desktop but fails across multiple Android devices, JavaScript compatibility or a mobile-specific resource loading issue would be worth investigating first.
