I’m querying Matomo using Postman, for example, like:
{{base_url}}/index.php?method=VisitsSummary.getVisits&idSite=21&period=range&date=2023-07-07,2023-07-07&module=API&format=JSON&token_auth={{matomo_token}}
This request is not working. I get a timeout after a while.
However, if I do this request instead:
{{base_url}}/index.php?method=VisitsSummary.getVisits&idSite=21&period=range&date=2023-07-06,2023-07-06&module=API&format=JSON&token_auth={{matomo_token}}
I get an answer like this:
"value": 291
What could be the reason for the first request to timeout?
The only thing that changes between requests in the range.
