da mein englisch nicht wirklich toll ist … werde ich hier alles genau schreiben…
also erstmal ich habe diesen Fehler
Kritischer Fehler während der Aktualisierung:
/home/www/piwik/core/Updates/1.5-b1.php:
Error trying to execute the query 'CREATE TABLE `piwik_log_conversion_item` (
idsite int(10) UNSIGNED NOT NULL,
idvisitor BINARY(8) NOT NULL,
server_time DATETIME NOT NULL,
idvisit INTEGER(10) UNSIGNED NOT NULL,
idorder varchar(100) NOT NULL,
idaction_sku INTEGER(10) UNSIGNED NOT NULL,
idaction_name INTEGER(10) UNSIGNED NOT NULL,
idaction_category INTEGER(10) UNSIGNED NOT NULL,
price FLOAT NOT NULL,
quantity INTEGER(10) UNSIGNED NOT NULL,
deleted TINYINT(1) UNSIGNED NOT NULL,
PRIMARY KEY(idvisit, idorder, idaction_sku),
INDEX index_idsite_servertime ( idsite, server_time )
) DEFAULT CHARSET=utf8 '.
The error was: SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'piwik_log_conversion_item' already exists
Anschließend habe ich Zeile für Zeile in die db rein gemacht was auch nix nutzte …
- Fehler: #1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘‘piwik_log_conversion_item’ ( idsite int(10) UNSIGNED NOT NULL, idvisitor BINARY’ at line 1
Code:
CREATE TABLE `piwik_log_conversion_item` ( idsite int(10) UNSIGNED NOT NULL, idvisitor BINARY(8) NOT NULL, server_time DATETIME NOT NULL, idvisit INTEGER(10) UNSIGNED NOT NULL, idorder varchar(100) NOT NULL, idaction_sku INTEGER(10) UNSIGNED NOT NULL, idaction_name INTEGER(10) UNSIGNED NOT NULL, idaction_category INTEGER(10) UNSIGNED NOT NULL, price FLOAT NOT NULL, quantity INTEGER(10) UNSIGNED NOT NULL, deleted TINYINT(1) UNSIGNED NOT NULL, PRIMARY KEY(idvisit, idorder, idaction_sku), INDEX index_idsite_servertime ( idsite, server_time ) ) DEFAULT CHARSET=utf8 ;
- Fehler: #1060 - Duplicate column name 'visit_goal_buyer’
Code:
ALTER IGNORE TABLE `piwik_log_visit` ADD visitor_days_since_order SMALLINT(5) UNSIGNED NOT NULL AFTER visitor_days_since_last, ADD visit_goal_buyer TINYINT(1) NOT NULL AFTER visit_goal_converted;
- Fehler: #1054 - Unknown column ‘visitor_days_since_first’ in 'piwik_log_conversion’
Code:
ALTER IGNORE TABLE `piwik_log_conversion` ADD visitor_days_since_order SMALLINT(5) UNSIGNED NOT NULL AFTER visitor_days_since_first, ADD idorder varchar(100) default NULL AFTER buster, ADD items SMALLINT UNSIGNED DEFAULT NULL, ADD revenue_subtotal float default NULL, ADD revenue_tax float default NULL, ADD revenue_shipping float default NULL, ADD revenue_discount float default NULL, ADD UNIQUE KEY unique_idsite_idorder (idsite, idorder), MODIFY idgoal int(10) NOT NULL;
- Fehler: #1060 - Duplicate column name 'custom_var_k1’
Code:
ALTER TABLE `piwik_log_link_visit_action` ADD custom_var_k1 VARCHAR(100) DEFAULT NULL AFTER time_spent_ref_action, ADD custom_var_v1 VARCHAR(100) DEFAULT NULL, ADD custom_var_k2 VARCHAR(100) DEFAULT NULL, ADD custom_var_v2 VARCHAR(100) DEFAULT NULL, ADD custom_var_k3 VARCHAR(100) DEFAULT NULL, ADD custom_var_v3 VARCHAR(100) DEFAULT NULL, ADD custom_var_k4 VARCHAR(100) DEFAULT NULL, ADD custom_var_v4 VARCHAR(100) DEFAULT NULL, ADD custom_var_k5 VARCHAR(100) DEFAULT NULL, ADD custom_var_v5 VARCHAR(100) DEFAULT NULL;
- Fehler: #1054 - Unknown column ‘custom_var_k1’ in 'piwik_log_conversion’
Code:
ALTER TABLE `piwik_log_conversion` CHANGE custom_var_k1 custom_var_k1 VARCHAR(100) DEFAULT NULL, CHANGE custom_var_v1 custom_var_v1 VARCHAR(100) DEFAULT NULL, CHANGE custom_var_k2 custom_var_k2 VARCHAR(100) DEFAULT NULL, CHANGE custom_var_v2 custom_var_v2 VARCHAR(100) DEFAULT NULL, CHANGE custom_var_k3 custom_var_k3 VARCHAR(100) DEFAULT NULL, CHANGE custom_var_v3 custom_var_v3 VARCHAR(100) DEFAULT NULL, CHANGE custom_var_k4 custom_var_k4 VARCHAR(100) DEFAULT NULL, CHANGE custom_var_v4 custom_var_v4 VARCHAR(100) DEFAULT NULL, CHANGE custom_var_k5 custom_var_k5 VARCHAR(100) DEFAULT NULL, CHANGE custom_var_v5 custom_var_v5 VARCHAR(100) DEFAULT NULL;
bitte bitte hilfe…
Danke!
mfg
Nosferatuvn
