I’ve used the SetCustomURL parameter due to us using a single page application. I’m wondering if using that on a landing page would wipe utm_parameters that are in the url (utm_source, utm_campaign, etc) and only show results as if it was direct. I’m running a set document title after setting a custom URL so the page shows up, but almost everything looks like it’s direct traffic.
Hi @Jeff_Rowley
Yes, this will remove these parameters. Then you have to copy them in the setCustomUrl.
