Is anyone out there willing to share how they use piwik with requirejs? I’m happily loading piwik as a module using the paths config (‘piwik’:’//myurl/piwik’) but I can’t seem to get it going from there. I’ve got the module below setup to try and pass the _paq object to other modules but it just seems to be a plain old array and doesn’t trigger anything on a _paq.push().
personnally i’m not familiar with it. If you are using it, would you mind contributing a small simple user doc? I will gladly add as a FAQ so other users can find it easier! thanks in advance.
It is possible to add piwik to your requirejs setup.
First add the the piwik server code in your paths config as you would a cdn:
paths: {
'piwik' : '//urltopiwikserver/piwik'
Then create a tracking module that depends on ‘piwik’ like so (and save it as say utils/tracking.js). Make sure to change the ‘urltopiwikserver’ and “setSiteId” variables to match your piwik setup :
define(['piwik'], function (piwik) {
"use strict";
var u;
_paq.push(["trackPageView"]);
_paq.push(["enableLinkTracking"]);
u = (("https:" === document.location.protocol) ? "https" : "http") + "://urltopiwikserver/";
_paq.push(["setTrackerUrl", u + "piwik.php"]);
_paq.push(["setSiteId", "2"]);
return _paq;
Then require your tracking module. You can use the _paq object to trigger other events etc within your application eg goal tracking:
/* Start the main app logic. */
requirejs([ 'util/tracking'], function ( _paq) {
_paq.push(['trackGoal', 1]);
