Using google tag manager and setting custom dimensions
Hi all,
First-time poster, short time lurker!
I am integrating matomo for a client and have already done google analytics successfully.
However, they want custom dimensions set when a trigger happens on the site. So I set the custom dimensions as per below when the page is loaded
var _paq = [];
  _paq.push(['setCustomDimension', customDimensionId = 15, customDimensionValue = 'A VALUE']);
    _paq.push(['setCustomDimension', customDimensionId = 1, customDimensionValue = 'not set']);
  _paq.push(['trackPageView']);
  (function() {
    var u="//OURPWIKI";
Then as it’s a single page app (no page refresh or hash changes) I trigger this code to push a new custom dimension to be set when a trigger happens (trigger successfully fires this code)
<script>
_paq.push(['setCustomDimension', customDimensionId = 1, customDimensionValue = '{{DataLayer - Property ID}}']);
</script>
Yet, this information isn’t coming through the system, what am I doing wrong?
Any help is VERY appreciated.
Thanks,
Michael
Hi there,
To me you need to send it along with an interaction, like an event or a new pageview.
How do I structure that?
I think the issue is that setCustomDimension doesn’t send any data to Matomo itself but only tells the next trackPageView to also send the customDimension that was changed locally.
See also
https://github.com/matomo-org/plugin-CustomDimensions/issues/31#issuecomment-221095332
So you always need to set custom Dimensions before tracking the page view.
