Using GeoIP 2 ina docker matomo and nginx and Maria
Hope y’all are doing well,
I have a problem.
I have 3 images.
1- Matomo:5.2.0
2- MariaDB:latest
3- Nginx:latest
This is the docker-compose:
services:
  matomoDb:
    image: mariadb:latest
    command: --max-allowed-packet=64MB
    restart: always
    ports:
      - "3306:3306"
    volumes:
      - matomoDb:/var/lib/mysql:Z
    env_file:
      - db.env
    networks:
      - custom_network
  matomo:
    build:
      context: .
      dockerfile: Dockerfile
    image: matomo-geoip:latest
    restart: always
    links:
      - matomoDb
    volumes:
      - matomo:/var/www/html:z
    networks:
      - custom_network
  matomoWeb:
    image: nginx:latest
    restart: always
    volumes:
      - matomo:/var/www/html:z,ro
      - ./default.conf:/etc/nginx/conf.d/default.conf:z
    ports:
      - "8082:80"
    networks:
      - custom_network  # Custom network for communication with other services
volumes:
  matomoDb:
  matomo:
networks:
  custom_network:
    driver: bridge
This is default.conf
upstream backend {
    server matomo:9000;  # Ensure the port is specified here
server {
    listen 80;
    root /var/www/html/;
    index index.php index.html index.htm;
    # Forward the real client IP and other necessary headers
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_set_header X-Real-IP $remote_addr;
    proxy_set_header Host $host;
    location / {
        try_files $uri $uri/ =404;
    location ~ \.php$ {
        fastcgi_pass backend;
        include fastcgi_params;
        fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
        # Forward client IP and real IP
    error_page 404 /404.html;
    error_page 500 502 503 504 /50x.html;
    location = /50x.html {
        root /usr/share/nginx/html;
After I set matomo up in the admin page, I go to
Settings → System → Geolocation, then I download the GeoIP 2 database.
and then I choose the
DBIP - GeoIp 2 (php) and save
I get the wrong IP address being resolved by GeoIP. The IP i get is docker Docker IP address.
How do I fix this, please?
Thank you all.
