Many of the users show up in Piwik twice. The log indicates the same IP Address, the same time, and the same pages visited. I am attaching a file with a screen shot of an example which shows this clearly. I will provide any details that would help, and I really appreciate any suggestions. I have not seen this issue on the Forum, so perhaps it is something in my set up. Thank you!
Let me clarify: when a user logs in to our website, that one login appears twice in the Piwik log. It is the same login, but shows up twice.
Your problem is you have the image tracker on there too… Look at the code I found on your site:
<!-- Piwik -->
var _paq = _paq || [];
// _paq.push(["setCookieDomain", "*.kirbyrisk.com"]);
// you can set up to 5 custom variables for each visitor
_paq.push(["setCustomVariable", 1, "Visitor Name", "Visitor Not Logged In", "visit"]);
_paq.push(["setCustomVariable", 2, "Visitor Account", "Visitor Not Logged In", "visit"]);
// you can set up to 5 custom variables for each action (page view, download, click, site search)
_paq.push(["setCustomVariable", 1, "Page Visitor", "Not Logged In Page", "page"]);
_paq.push(["setCustomVariable", 2, "Page Account", "Not Logged In Page", "page"]);
_paq.push(["trackPageView"]);
_paq.push(["enableLinkTracking"]);
(function() {
var u=(("https:" == document.location.protocol) ? "https" : "http") + "://coney.arvixe.com/~kirbyweb/";
_paq.push(["setTrackerUrl", u+"piwik.php"]);
_paq.push(["setSiteId", "3"]);
var d=document, g=d.createElement("script"), s=d.getElementsByTagName("script")[0]; g.type="text/javascript";
g.defer=true; g.async=true; g.src=u+"piwik.js"; s.parentNode.insertBefore(g,s);
</script>
<!-- End Piwik Code -->
<!-- Piwik Image Tracker -->
<img src="https://coney.arvixe.com/~kirbyweb/piwik.php?idsite=3&rec=1" style="border:0" alt="" />
<!-- End Piwik -->
The following lines should be removed:
<!-- End Piwik -->
You should only run one at a time…
Actually you can add that code in between the no script tags like below:
Using this makes it where only if JS is not present or available, then it will revert back to the image tracker.
<noscript>
<!-- End Piwik -->
</noscript>
Thank you! I’m sure that is correct.
At one point, I had the tracker code in between tags, and removed the tags to test something. I put it back in there. Thanks for guiding me to this. I should have seen it myself!
No problem. Just glad to know I helped!
