Does the Users Flow plugin allow you to analyse user flows from before the plugin was installed, or does it only record them from after the time that the plugin was installed an activated?
Thanks!
Thanks!
Yes, install the plugin and reprocess your reports to visualise users flow for data prior to the plugin installation.
Thanks,
