Within the Goals tab, one can select Campaigns to follow conversions. Unfortunately, there seems to be a bug splitting some compaigns into a upper and lower case version of both the campaign and the keyword string.
This is the URL hash part: [size=small]module=Goals&action=goalReport&idSite=1&period=range&date=previous7&idGoal=3[/size]; I have attached a picture of one example but it really happens in a much wider spread.
The lower case version gets the visits and the upper case the conversions, leading to a false report of 0% rates everywhere.
I am 100% certain that the incoming links only use the version containing upper case letters!
Is this a known bug? It looks like a side effect of Make campaign name and campaign keyword lowercase when tracking · Issue #4260 · matomo-org/matomo · GitHub. How can I help the community to prevent this? I am willing to upload a database dump.
I’m running Piwik version 2.1-RC1 (possibly updated while the campaign was active).
Solved as follows (please comment if there is a better way or that it causes problems down the road):
[ol]
[li] Applied the patch from https://github.com/piwik/piwik/commit/4c5f26b8e5ff5a2c38212d5aa9cc1fcb1ea87206#diff-b02e7b361f37b6082c3cf79936053be1R869, which comes from the bug tracker linked in my post above
[/li][li] Ran the following SQL: UPDATE piwik_log_conversion SET referer_name=LOWER(referer_name), referer_keyword=LOWER(referer_keyword) WHERE referer_type=6
[/li][li] And this SQL: UPDATE piwik_log_visit SET referer_name=LOWER(referer_name), referer_keyword=LOWER(referer_keyword) WHERE referer_type=6
[/li][li] emptied Piwik’s tmp directory
[/li][li] deleted the 2 archive tables for this month from the database
[/li][li] re-ran cron (needed some --force)
[/li][li] cleared browser cache and voilà!
[/li][/ol]
Each campaign and keyword is now listed just once, as it should.
Unfortunately, this still seems to be a problem with Matomo 5.2.1.
Just to confirm, it didn’t seem to be a problem until somewhere around 5.1.0 and 5.2.0. Unfortunately I’ve got my setup enabled to delete old raw data after 30 days so it’s hard to check exactly when. ‘Keep campaign parameter capitalisation’ is definitely disabled.
