I just upgraded to 2.14 and it works as long as I am logged in as admin in another window. When I log out, same error “Error: You can’t access this resource as it requires an ‘view’ access for the website id = ID”.
The token_auth is correct but doesn’t seem to come through. In the Users Management table the LAST SEEN column shows a time lap from just before the upgrade.
most of the widget fixed in 2.14.1-b1, however, some widgets such as “browser types”, it shows an error page:
The plugin UserSettings is not enabled. You can activate the plugin on Settings > Plugins page in Piwik.
https://<my_domain>/index.php?action=iframe&actionToWidgetize=getMobileVsDesktop&disableLink=1&idSite=71&language=zh-cn&module=Widgetize&moduleToWidgetize=UserSettings&token_auth=<my_token>&widget=1&period=range&date=2015-06-13,2015-07-12
However when I go into that setting page, can’t find any setting for that…
It looks your permission issue has been solved, but you deal with another issue. Some moduleToWidgetize / actionToWidgetize have been altered several versions ago. UserSettings is not available anymore. You can check the right combi’s in Widgetize reports.
