We have running now for quite some time the latest stable build, prior to the latest version 0.5.3. And i can not upgrade correctly.
What i did:
Downloaded the file -> latest.zip
decompressed it on my pc
uploaded (overwriting the exsisting files)
and i got all Zend Warnings
When i corrected the writing permissions in the /tmp folder i still get the message
with the announcement to upgrade (spanish version)
[size=10pt]Piwik 0.5.3 está disponible.
¡Por favor, actualice ahora! (ver cambios). [/size]
Can anybody help me out here, plz? style_emoticons/<#EMO_DIR#>/dry.gif
Did i do something wrong? style_emoticons/<#EMO_DIR#>/sad.gif
Many thanks,
Paco
Decompressed the file in the empty piwik folder (no overwrite!!!) and copied the file config.ini.php from my old installation into the subfolder config
cinterpro, if you have Zend errors, it most likely means that some fiels havent uploaded properly. The instructions can be found at: http://piwik.org/docs/update/#manual
That’s ist!
Regards,
Carsten[/quote]
Hello Carsten…
Did now the same thing i created a folder called /lastest/ uncompressed the files and copied the config.ini.php file to the config folder…
But guess what… i still see the image that i have to upgrade
orignal version: h t t p://estadisticas.computerinterpro.es/
Lates version in: h t t p://estadisticas.computerinterpro.es/latest/
hmmm… strange tough…
Thanks for your instructions.
regards,
Paco
Dear matthieu.
Thanks for the tip… but aftwards i uploaded the file latest.zip in binaymode to
my server and unzipped it…
But as you can see from the answer i gave to Carsten (Posted Yesterday, 05:06 PM)
i still get the image informing me that i should upgrade…
any ideas. Did i maybe do someting wrong in the steps mentioned?
Hoping to hear from you again.
regards from a cold madrid.
paco
Dear Mattieu.
thanks for the excellent TIP. seems i am allmost there…never the less
it now says “You can now enable the new MultiSites plugin in the Plugins screen in the Piwik admin!”
h t t p://estadisticas.computerinterpro.es/new/index.php
Any ideas on this?
Many thanks for the help received…
Paco
