Have decided to upgrade to the new beta and test it out.
I hit auto-upgrade, and after a little while, the page hung, loading, with a white screen.
I reopened the page, and got the message:
Piwik database will be upgraded from version 2.0-a12 to the new version 2.0-b1.
Which is odd, as I was upgrading from stable, not from 2.0-a12.
Anyways, I hit “upgrade piwik”, and got the message:
Critical Error during the update process:
/var/piwik/core/Updates/2.0-a13.php:
Error trying to execute the query 'UPDATE piwik_option
SET option_name
= ‘version_ScheduledReports’ WHERE option_name
= ‘version_PDFReports’ '.
The error was: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘version_ScheduledReports’ for key ‘PRIMARY’
(Command line had same results).
I will follow the steps suggested (“advanced user”) , and report back, but wanted to know if (a) the is anything extra to lookout for as am doing a version upgrade. and (b) wanted to alert you to an issue in the one-click upgrade.
Thank you for your hard work.
