hello,
i just wanted to update my piwik v 0.4.1 to 0.6.1.
i didnt find a possibilty to update automatically, so i wanted to do it manually.
i renamed my piwik folder to piwik_old, restored my config.ini.php and uploaded the new piwik files on my webspace. then i copied my config.ini.php back to the new folder and browsed to my piwik-site.
a “Database Upgrade Required” screen appeared with an error message:
“File integrity check failed and reported some errors. This is most likely due to a partial or failed upload of some of the Piwik files. You should reupload all the Piwik files and refresh this page until it shows no error.”
i uploaded the whole folder a second time, but same error occurs.
can you help me please?
thanks a lot.
