Update-Problem: Warning - preg_match(): Unknown modifier 'w'
(Marc Mertens (QuerKommentar)) #1
Hello from Germany,
I got the message that there is an update for piwik to Version 2.12 and made it with the autoupdate-function.
Before that, everything works fine and i had no error messages.
Now there comes up:
WARNING: /mnt/webj/e1/43/51186643/htdocs/WebAnalyse/core/Url.php(252): Warning - preg_match(): Unknown modifier ‘w’ - Piwik 2.12.0
and the Javascript-Tracking-Code should be integrated, but it still is!
I made no changes to the directory in which the files are stored. The config.ini.php is correctly set to my URL: “marcmertens.photography/WebAnalyse” Caused by this error I load up the files with FileZille another time manually.
Piwik should be used for my own Wordpress-Blog under: QuerKommentar.de and there i use the WP-Piwik-PlugIn.
PS:
I am new with Piwik and just started the tool. So I have still to learn a lot of things about it.
Thanks for the support and time.
Greetings,
Marc
(Matthieu Aubry) #2
Hi Marc
can you please paste the lines “trusted_hosts” from your config.ini,php?
Likely one contains a little typo, but still would be good if you pasted the lines here
(Marc Mertens (QuerKommentar)) #3
Hello Matt,
I hope you mean this?:
trusted_hosts[] = “marcmertens.photography/WebAnalyse”
This is the location where I installed (uploaded) the extracted piwik files.
PS:
But in the meantime I found, that the “WP-Piwik”-Plugin recognizes the right Version of my installation. Maybe, something went wrong with the auto-update-function and this plugin, or not? I don´t made essential changes on piwik since the first setup yesterday. :wink:
Thank you.
Marc
(Matthieu Aubry) #4
Change:
to:
trusted_hosts[] = “marcmertens.photography”
This should fix the issue for now.
(Marc Mertens (QuerKommentar)) #5
Hello Matt,
Thank you for your support and time. (tu) :slight_smile:
I just uploaded the edited config-file manually and now the errors are gone.
But it seems to be a liitle curious, that my changes in the administration panel of the URL-Section of this config-entry after the errors show up had not the same effect. Maybe there could be a problem.
The message of the missing java-script-tracking-snippet in my WordPress-Installation is still there. But in the meantime I will look into the admin panel of my weblog.
Kind regards,
Marc
(Matthieu Aubry) #6
Do you remember maybe putting
manually in your config file?
or are you sure that this was added automatically?
