fearby
(Simon Fearby)
March 4, 2019, 2:21am
1
I manually tried to update my matomo (as I have no ftp server by choice), I followed Update Piwik User Guide - Analytics Platform - Matomo I was using 3.6.1 and backed up my config.ini.php, downloaded “wget https://builds.piwik.org/piwik.zip ” and unzipped over the matomo install. I logged into matomo and spotted the usual banner saying to update but no idea how I trigger this?
I am re downloading piwik.zip to verify the version but its slow at 4.8KB/sec
fearby
(Simon Fearby)
March 4, 2019, 2:42am
2
It appears as if https://builds.piwik.org/piwik.zip if Matomo 3.8.0 not 3.8.1?
fearby
(Simon Fearby)
March 4, 2019, 2:53am
3
https://builds.piwik.org/matomo.zip is Matomo 3.8.0 too??? How do I get 3.8.1?
Lukas
(Lukas Winkler)
March 4, 2019, 6:56am
4
I just downloaded both files and they are fine (and according to https://builds.piwik.org/ haven’t been changed since the release).
Can you check the core/Version.php
file in the zip? It should mention which version the zip really is.
* Matomo version information.
* @api
final class Version
* The current Matomo version.
* @var string
const VERSION = '3.8.1';
public function isStableVersion($version)
return (bool) preg_match('/^(\d+)\.(\d+)\.(\d+)$/', $version);
public function isVersionNumber($version)
return $this->isStableVersion($version) || $this->isNonStableVersion($version);
fearby
(Simon Fearby)
March 4, 2019, 10:20pm
5
Right you are, “version.php” does indeed list v3.8.1, CHANGELlog.md says “Matomo 3.8.0”. I’ll try again.
I did backup config, delete the old install, extract the new install and it said 3.8.1 was available?? are updates easier over ftp?
Thanks
fearby
(Simon Fearby)
March 4, 2019, 10:21pm
6
Whats the diff between piwik.zip and matomo.zip (are they the same?)
Lukas
(Lukas Winkler)
March 4, 2019, 10:35pm
7
CHANGELOG.md isn’t the changelog of the Matomo application (you can find it at https://matomo.org/changelog ), but just changes for developers.
As 3.8.1 is a bugfix release, there were no breaking changes.
The zip files are both the same, it is just for backwards compatibility.
