When i try to auto update Piwik from 2.12.1 to 2.13.0 i get this error :
curl_exec: SSL certificate problem: unable to get local issuer certificate. Hostname requested was: builds.piwik.org
Anyone can help me please ?
Thanks
Thanks
Hi there,
Unfortunately 2.12.1 had an issue - so you may have to manually upgrade to 2.13.0 with manual upload
(unless Piwik lets you choose to one click upgrade over HTTP non secure which you can try instead)
We should have fixed this in Include certificates for update over HTTPS? · Issue #7580 · matomo-org/piwik · GitHub by adding the certificate authorities file in piwik.
Hopefully once you upgrade to 2.13.0 and then to 2.14.0 in a month or so, it should work then.
Ok thanks for your reply
Note, he didn’t say you can wait until 2.14. You have to go to 2.13 to get the fixed code first. Then the automatic update to 2.14 will work again. Just saying that as it sounds like you are going to wait …
