Notice: Undefined index: sitesearch in /var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/Site.php on line 260
Backtrace -->
#0 Piwik_ErrorHandler(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/Site.php:260] #1 Piwik_Site::getFor(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/Site.php:326] #2 Piwik_Site::isSiteSearchEnabledFor(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/plugins/Actions/Actions.php:558] #3 Piwik_Actions->isSiteSearchEnabled(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/plugins/Actions/Actions.php:546] #4 Piwik_Actions->addMenus(…) called at [:] #5 call_user_func_array(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/libs/Event/Dispatcher.php:284] #6 Event_Dispatcher->postNotification(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/PluginsManager.php:668] #7 Piwik_PostEvent(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/Menu/Main.php:65] #8 Piwik_Menu_Main->get(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/Menu/Main.php:90] #9 Piwik_GetMenu(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/plugins/CoreHome/Controller.php:58] #10 Piwik_CoreHome_Controller->getDefaultIndexView(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/plugins/CoreHome/Controller.php:92] #11 Piwik_CoreHome_Controller->index(…) called at [:] #12 call_user_func_array(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/FrontController.php:138] #13 Piwik_FrontController->dispatch(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/index.php:53]
There is an error. Please report the message (Piwik 1.9) and full backtrace in the Piwik forums (please do a Search first as it might have been reported already!).
Notice: Undefined index: sitesearch in /var/www/clients/client1/web1/web/report/core/Site.php on line 260
Backtrace -->
#0 Piwik_ErrorHandler(…) called at [/var/www/clients/client1/web1/web/report/core/Site.php:260] #1 Piwik_Site::getFor(…) called at [/var/www/clients/client1/web1/web/report/core/Site.php:326] #2 Piwik_Site::isSiteSearchEnabledFor(…) called at [/var/www/clients/client1/web1/web/report/plugins/Actions/Actions.php:558] #3 Piwik_Actions->isSiteSearchEnabled(…) called at [/var/www/clients/client1/web1/web/report/plugins/Actions/Actions.php:402] #4 Piwik_Actions->getReportMetadata(…) called at [:] #5 call_user_func_array(…) called at [/var/www/clients/client1/web1/web/report/libs/Event/Dispatcher.php:284] #6 Event_Dispatcher->postNotification(…) called at [/var/www/clients/client1/web1/web/report/core/PluginsManager.php:668] #7 Piwik_PostEvent(…) called at [/var/www/clients/client1/web1/web/report/plugins/API/API.php:543] #8 Piwik_API_API->getReportMetadata(…) called at [/var/www/clients/client1/web1/web/report/plugins/API/API.php:490] #9 Piwik_API_API->getMetadata(…) called at [/var/www/clients/client1/web1/web/report/core/ViewDataTable.php:1206] #10 Piwik_ViewDataTable->loadDocumentation(…) called at [/var/www/clients/client1/web1/web/report/core/ViewDataTable.php:1195] #11 Piwik_ViewDataTable->getReportDocumentation(…) called at [/var/www/clients/client1/web1/web/report/core/ViewDataTable/GenerateGraphHTML.php:157] #12 Piwik_ViewDataTable_GenerateGraphHTML->buildView(…) called at [/var/www/clients/client1/web1/web/report/core/ViewDataTable/GenerateGraphHTML.php:125] #13 Piwik_ViewDataTable_GenerateGraphHTML->main(…) called at [/var/www/clients/client1/web1/web/report/core/Controller.php:152] #14 Piwik_Controller->renderView(…) called at [/var/www/clients/client1/web1/web/report/plugins/DBStats/Controller.php:72] #15 Piwik_DBStats_Controller->getDatabaseUsageSummary(…) called at [/var/www/clients/client1/web1/web/report/plugins/DBStats/Controller.php:33] #16 Piwik_DBStats_Controller->index(…) called at [:] #17 call_user_func_array(…) called at [/var/www/clients/client1/web1/web/report/core/FrontController.php:138] #18 Piwik_FrontController->dispatch(…) called at [/var/www/clients/client1/web1/web/report/index.php:53]
I’m having the same problem. Have tried the manual update which didn’t work, the auto update… It seems that the database doesn’t get updated via the update script.
It doesn’t add the new fields in the database for SiteSearch and all the others that come with 1.9.
Well, the database isn’t updated and still on version 1.8.4. You have to delete all the 1.9 files and upload the 1.8.4 ones back into the same folder. Then you’ll run through the install process again, where you KEEP your database instead of deleting it. Fill every field with the exact same information as before the 1.9 update.
So when you’re done with this, you have a unchanged database with the 1.8.4 files again.
[quote=mvandek]
[quote=matt]
If you see this error, it means the update script was not executed properly.
Run this SQL query to force piwik to re-run the update:
UPDATE piwik_option SET value='1.8.4' WHERE name='version_core'
Also, make sure the new files are uploaded correctly, you should have files in piwik/core/Updates/1.9-XXXXX.php ?[/quote]
I’ve changed all the rows in piwik_option manually, which contained 1.9 back into 1.8.4 and ran the update again. This time the database upgrade was performed and it runs like it’s supposed to be.
Notice: Undefined index: archiving_ranking_query_row_limit in /var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/plugins/Actions/Archiving.php on line 423
Backtrace -->
#0 Piwik_ErrorHandler(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/plugins/Actions/Archiving.php:423] #1 Piwik_Actions_Archiving::getRankingQueryLimit(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/plugins/Actions/Archiving.php:93] #2 Piwik_Actions_Archiving->archiveDay(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/plugins/Actions/Actions.php:592] #3 Piwik_Actions->archiveDay(…) called at [:] #4 call_user_func_array(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/libs/Event/Dispatcher.php:284] #5 Event_Dispatcher->postNotification(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/core/PluginsManager.php:668] #6 Piwik_PostEvent(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/core/ArchiveProcessing/Day.php:45] #7 Piwik_ArchiveProcessing_Day->compute(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/core/ArchiveProcessing.php:498] #8 Piwik_ArchiveProcessing->launchArchiving(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/core/Archive/Single.php:236] #9 Piwik_Archive_Single->prepareArchive(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/core/Archive/Array/IndexedBySite.php:192] #10 Piwik_Archive_Array_IndexedBySite->getArchiveIdsAfterLaunching(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/core/Archive/Array/IndexedBySite.php:131] #11 Piwik_Archive_Array_IndexedBySite->loadValuesFromDB(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/core/Archive/Array/IndexedBySite.php:108] #12 Piwik_Archive_Array_IndexedBySite->getValues(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/core/Archive/Array/IndexedBySite.php:73] #13 Piwik_Archive_Array_IndexedBySite->getDataTableFromNumeric(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/plugins/MultiSites/API.php:192] #14 Piwik_MultiSites_API->buildDataTable(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/plugins/MultiSites/API.php:112] #15 Piwik_MultiSites_API->getAll(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/plugins/MultiSites/Controller.php:65] #16 Piwik_MultiSites_Controller->getSitesInfo(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/plugins/MultiSites/Controller.php:36] #17 Piwik_MultiSites_Controller->index(…) called at [:] #18 call_user_func_array(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/core/FrontController.php:138] #19 Piwik_FrontController->dispatch(…) called at [/var/www/vhosts/click-business.de/subdomains/analytics/httpdocs/index.php:53]
I tried the query but the version was on 1.9 already
I used the prompt based update procedure. This was running fine.
I have the same problem with 1.9.1.
I update the option_value in my database to 1.8.4 and I reload the page : /piwik/index.php?module=CoreUpdater&action=newVersionAvailable
But not issu.
Thank you.
Thomas
There is an error. Please report the message (Piwik 1.9.1) and full backtrace in the Piwik forums (please do a Search first as it might have been reported already!).
Backtrace -->
#0 Piwik_ErrorHandler(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/Site.php:260] #1 Piwik_Site::getFor(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/Site.php:326] #2 Piwik_Site::isSiteSearchEnabledFor(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/plugins/Actions/Actions.php:558] #3 Piwik_Actions->isSiteSearchEnabled(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/plugins/Actions/Actions.php:546] #4 Piwik_Actions->addMenus(…) called at [:] #5 call_user_func_array(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/libs/Event/Dispatcher.php:284] #6 Event_Dispatcher->postNotification(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/PluginsManager.php:722] #7 Piwik_PostEvent(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/Menu/Main.php:65] #8 Piwik_Menu_Main->get(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/Menu/Main.php:90] #9 Piwik_GetMenu(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/plugins/CoreHome/Controller.php:58] #10 Piwik_CoreHome_Controller->getDefaultIndexView(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/plugins/CoreHome/Controller.php:92] #11 Piwik_CoreHome_Controller->index(…) called at [:] #12 call_user_func_array(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/core/FrontController.php:138] #13 Piwik_FrontController->dispatch(…) called at [/var/www/vhosts/heberg.gratuit-domaine.eu/httpdocs/piwik/index.php:53]
