I have a requirement to track the unique number of visitors to a web page, from what I understand, piwik does the unique tracking by the IP address/OS and visitors using first party cookies.
But for my application, if two different people are using the same computer (ip), they should be treated as seperate visitors. For this I am using JSESSION_ID and planning to use a custom variable to achieve the same.
a) Is this the correct approach ?
b) While using custom variable, under the Visitors -> Custom variable, though i am able to see the list of unique visitors, the total count for same is not reflected against the unique visitors reported?
Is there any custom setting required at my end ? Please help
All am doing in my code is to check the SESSION ID for null, if not null am setting it to a custom variable value
Below is the code for same
var myVar = “<s:property value=’%{sessionID}’/>”;
if(myVar==null || myVar==undefined || myVar==’’){
alert(null);
}else{
piwikTracker.setCustomVariable(1, ‘UniquevisitorHBE’,myVar,‘visit’);
piwikTracker.trackPageView();
