I just configured Piwik on an Internal IIS Server and added few Intranet sites to trace.
Not Sure why, piwik is unable to get any information??
If i browse the sites from the IIS Server where I have configured Piwik it is picking up the details, However when I browse from my PC or iPad Piwik shows nothing.
I checked the Site and Forum and configured config.ini.php file
[General]
trusted_hosts[] = “trusted host name here”
[Tracker]
trust_visitors_cookies = 1
[proxy]
host = "proxy server name"
port = 80
Is there anything i’m missing?? Could someone help please…
When i tried from Chrome on my Laptop, I see that Piwik object(marked in red) coming from piwik.js is showing as “NOT DEFINED”… but the same code works on the local server. Any idea on what should I do?
Matt, the piwik code is valid and i’m able to track Firfox, Safari and Chrome visits… But for IE its not working. I checked for any extension i might have installed in IE and there are none.
Not sure where else i need to check. could you please help. thank you.
Hi Matt, you were right!
Piwik tracks the IE visits when I trun off the DNT in IE… Is there a way where piwik can automatically ignore the DNT requests from IE???
