Trouble with "check system": Entry Piwik\Plugins\Diagnostics\DiagnosticService cannot be resolved
#1
Hello!
When I click on “check system” I see next messages:
Entry Piwik\Plugins\Diagnostics\DiagnosticService cannot be resolved: The parameter ‘mandatoryDiagnostics’ of Piwik\Plugins\Diagnostics\DiagnosticService::__construct has no value defined or guessableFull definition:Object ( class = Piwik\Plugins\Diagnostics\DiagnosticService scope = singleton lazy = false __construct( $mandatoryDiagnostics = #UNDEFINED# $optionalDiagnostics = #UNDEFINED# $disabledDiagnostics = #UNDEFINED# ))
Please,help me. How can I fix it?
P.S. I use piwik version 2.13.1
(Matthieu Aubry) #2
Hi there,
Thanks for the report. This is a new bug in Piwik. can you please report this in an issue at: Issues · matomo-org/piwik · GitHub ? we will follow up
#3
Hi Matt,
Is this bug resolved in the new release 2.14? or is your team still working on it?
Thanks,
Dilish
(Matthieu Aubry) #4
this bug should be fixed in 2.14.0
#5
In 2.14.2 I have the same problem:
Detlef
(Matthieu Aubry) #6
Hi there,
Can you please create a bug report at: Issues · matomo-org/piwik · GitHub - we will investigate
