Hi to all,
Well directly to the subject.
I was planning to translate piwik in my native language.
Installed the translation plugin everything ok.
I went to the translation tab
there i started to translate, no problems but in the language code there was “en”.
Ok I thought no prob.
All the changes I did where instantly shown since my language was english and i was editing that file , no?
The in the settings i noticed the "Languages " tab and how nice there was an add language button so I decided to add my language “el”. But then the LanguageManager plugin crashed giving on the background the contents of the codebox below.
Any suggestions.
I tried to upload again the LanguagesManager plugin but nothing,
I did the same for the Translation plugin, nothing.
Notice: Undefined index: General_OriginalLanguageName in /piwik/plugins/LanguagesManager/API.php on line 55
Backtrace -->
#0 Piwik_ErrorHandler(8, Undefined index: General_OriginalLanguageName, /piwik/plugins/LanguagesManager/API.php, 55, Array ([filenames] => Array ([0] => ca,[1] => de,[2] => el,[3] => en,[4] => es,[5] => fr,[6] => hu,[7] => it,[8] => ja,[9] => nl,[10] => no,[11] => pl,[12] => pt,[13] => ru,[14] => sk,[15] => sr,[16] => sv,[17] => uk,[18] => zh-cn,[19] => zh-tw),[filename] => el,[translations] => Array (),[languagesInfo] => Array ([0] => Array (
=> ca,[name] => Català),[1] => Array (
=> de,[name] => Deutsch)))) called at [ /piwik/plugins/LanguagesManager/API.php:55]
#1 Piwik_LanguagesManager_API::getAvailableLanguageNames() called at [ /piwik/plugins/LanguagesManager/LanguagesManager.php:42]
#2 Piwik_LanguagesManager->showLanguagesSelector(Event_Notification Object ([_notificationName] => template_topBar,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0)) called at [(null):0]
#3 call_user_func_array(Array ([0] => Piwik_LanguagesManager Object (),[1] => showLanguagesSelector), Array ([0] => Event_Notification Object ([_notificationName] => template_topBar,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0))) called at [ /piwik/libs/Event/Dispatcher.php:280]
#4 Event_Dispatcher->postNotification(Event_Notification Object ([_notificationName] => template_topBar,[_notificationObject] => ,[_notificationInfo] => Array (),[_notificationState] => 0,[_notificationCount] => 0), 1, ) called at [ /piwik/libs/Event/Dispatcher.php:250]
#5 Event_Dispatcher->post(, template_topBar, Array (), 1, ) called at [ /piwik/core/PluginsManager.php:473]
#6 Piwik_PostEvent(template_topBar, ) called at [ /piwik/core/SmartyPlugins/function.postEvent.php:40]
#7 smarty_function_postEvent(Array ([name] => template_topBar), Piwik_Smarty Object ([template_dir] => Array ([0] => plugins,[1] => themes/default,[2] => themes),[compile_dir] => tmp/templates_c,[config_dir] => configs,[plugins_dir] => Array ([0] => libs/Smarty/plugins,[1] => core/SmartyPlugins),[debugging] => 1,[error_reporting] => 6143,[debug_tpl] => ,[debugging_ctrl] => NONE,[compile_check] => 1,[force_compile] => ,[caching] => 0,[cache_dir] => tmp/cache,[cache_lifetime] => 3600,[cache_modified_check] => ,[php_handling] => 0,[security] => ,[secure_dir] => Array (),[security_settings] => Array ([PHP_HANDLING] => ,[IF_FUNCS] => Array ([0] => array,[1] => list,[2] => isset,[3] => empty,[4] => count,[5] => sizeof,[6] => in_array,[7] => is_array,[8] => true,[9] => false,[10] => null),[INCLUDE_ANY] => ,[PHP_TAGS] => ,[MODIFIER_FUNCS] => Array ([0] => count),[ALLOW_CONSTANTS] => ),[trusted_dir] => Array (),[left_delimiter] => {,[right_delimiter] => },[request_vars_order] => EGPCS,[request_use_auto_globals] => 1,[compile_id] => ,[use_sub_dirs] => ,[default_modifiers] => Array (),[default_resource_type] => file,[cache_handler_func] => ,[autoload_filters] => Array (),[config_overwrite] => 1,[config_booleanize] => 1,[config_read_hidden] => ,[config_fix_newlines] => 1,[default_template_handler_func] => ,[compiler_file] => Smarty_Compiler.class.php,[compiler_class] => Smarty_Compiler,[config_class] => Config_File,[_tpl_vars] => Array ([SCRIPT_NAME] => /piwik/piwik/index.php,[piwikUrl] => [http://www.ageri.gr/piwik/piwik/[/url],[pluginsName] => Array ([API] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => API,[description] => All the data in Piwik is available through simple APIs. This plugin is the web service entry point, that you can call to get your Web Analytics data in xml, json, php, csv, etc. Discover the Piwik APIs.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[Actions] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Actions,[description] => Reports about the page views, the outlinks and downloads. Outlinks and Downloads tracking is automatic!,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[CoreAdminHome] => Array ([activated] => 1,[alwaysActivated] => 1,[info] => Array ([name] => Administration area,[description] => Administration area of Piwik.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[CoreHome] => Array ([activated] => 1,[alwaysActivated] => 1,[info] => Array ([name] => Homepage,[description] => Web Analytics Reports Structure.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[CorePluginsAdmin] => Array ([activated] => 1,[alwaysActivated] => 1,[info] => Array ([name] => Plugins Management,[description] => Plugins Administration Interface.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[CoreUpdater] => Array ([activated] => 1,[alwaysActivated] => 1,[info] => Array ([name] => Updater,[description] => Piwik updating mechanism,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[DBStats] => Array ([activated] => ,[alwaysActivated] => ,[info] => Array ([name] => Databases statistics,[description] => This plugin reports the database usage by Piwik tables.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[Dashboard] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Dashboard,[description] => Your Web Analytics Dashboard. You can customize Your Dashboard: add new widgets, change the order of your widgets. Each user can access his own custom Dashboard.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[ExampleAPI] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Example API,[description] => Example Plugin: How to create an API for your plugin, to export your data in multiple formats without any special coding? Visit the ExampleAPI example methods.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[ExampleFeedburner] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Example Feedburner,[description] => Example Plugin: How to display your Feedburner subscriber in a Widget in the Dashboard?,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[ExamplePlugin] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Example Plugin,[description] => Example Plugin: This plugin shows how to create a very simple plugin, that exports two widgets in the Dashboard.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[ExampleRssWidget] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Example Rss Widget,[description] => Example Plugin: How to create a new widget that reads a RSS feed?,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[Feedback] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Feedback,[description] => Send your Feedback to the Piwik Team in one click. Share your ideas and suggestions with us!,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[Goals] => Array ([activated] => ,[alwaysActivated] => ,[info] => Array ([name] => (ALPHA) Goal Tracking,[description] => Create Goals and see reports about your goal conversions: evolution over time, revenue per visit, conversions per referer, per keyword, etc.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1,[TrackerPlugin] => 1)),[Installation] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Installation,[description] => Installation process of Piwik. The Installation is usually done once only. If the configuration file config/config.inc.php is deleted, the installation will start again.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[LanguagesManager] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Languages Management,[description] => This plugin will display a list of the available languages for the Piwik interface. The language selected will be saved in the preferences for each user.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[Live] => Array ([activated] => ,[alwaysActivated] => ,[info] => Array ([name] => Live Visitors,[description] => Live Visitors!,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[Login] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Login,[description] => Login Authentication plugin, reading the credentials from the config/config.inc.php file for the Super User, and from the Database for the other users. Can be easily replaced to introduce a new Authentication mechanism (OpenID, htaccess, custom Auth, etc.).,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[Provider] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Provider,[description] => Reports the Provider of the visitors.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1,[TrackerPlugin] => 1)),[Referers] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Referers,[description] => Reports the Referers data: Search Engines, Keywords, Websites, Campaign Tracking, Direct Entry. ,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[SitesManager] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Sites Management,[description] => Websites Management in Piwik: Add a new Website, Edit an existing one, Show the Javascript code to include on your pages. All the actions are also available through the API.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[TranslationsAdmin] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => TranslationsAdmin,[description] => ,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[UserCountry] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Visitors Country,[description] => Reports the Country of the visitors.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[UserSettings] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Visitors Settings,[description] => Reports various User Settings: Browser, Browser Family, Operating System, Plugins, Resolution, Global Settings.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[UsersManager] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Users Management,[description] => Users Management in Piwik: add a new User, edit an existing one, update the permissions. All the actions are also available through the API.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[VisitFrequency] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Visits Frequency,[description] => Reports various statistics about the Returning Visitor versus the First time visitor.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[VisitTime] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Visits Time,[description] => Reports the Local and Server time. Server time information can be useful to schedule a maintenance on the Website.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1)),[VisitorInterest] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Visitors Interest,[description] => Reports about the Visitor Interest: number of pages viewed, time spent on the Website.,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/](http://www.ageri.gr/piwik/piwik/),[version] => 0.1)),[VisitsSummary] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Visits Summary,[description] => Reports the general Analytics numbers: visits, unique visitors,
number of actions, Bounce Rate, etc.,[author] => Piwik,[homepage] => [http://piwik.org/[/url],[version] => 0.1)),[Widgetize] => Array ([activated] => 1,[alwaysActivated] => ,[info] => Array ([name] => Widgetize your data!,[description] => The plugin makes it very easy to export any Piwik Widget in your Blog, Website or on Igoogle and Netvibes!,[author] => Piwik,[homepage] => [url=http://piwik.org/]http://piwik.org/[/url],[version] => 0.1))),[menu] => Array ([Plugins] => Array ([module] => CorePluginsAdmin,[action] => index),[Users] => Array ([module] => UsersManager,[action] => index),[Sites] => Array ([module] => SitesManager,[action] => index),[Translations] => Array ([module] => TranslationsAdmin,[action] => index),[Languages] => Array ([module] => TranslationsAdmin,[action] => languages)),[currentModule] => CorePluginsAdmin,[currentPluginName] => Plugins Management,[userLogin] => admin,[sites] => Array ([0] => Array ([idsite] => 1,[name] => [url=http://ageri.gr]http://ageri.gr[/url],[main_url] => [url=http://www.ageri.gr]http://www.ageri.gr[/url],[ts_created] => 2009-03-12 12:59:39,[feedburnerName] => )),[showWebsiteSelectorInUserInterface] => 1,[url] => [url=http://www.ageri.gr/piwik/piwik/index.php?module=CorePluginsAdmin]http://www.ageri.gr/piwik/piwik/index.php?...orePluginsAdmin](http://piwik.org/),[token_auth] => c7b807083937d86cfee2cee448a840ed,[userHasSomeAdminAccess] => 1,[userIsSuperUser] => 1,[piwik_version] => 0.2.32,[latest_version_available] => ,[totalTimeGeneration] => 0.069,[totalNumberOfQueries] => 0,[showSitesSelection] => ,[showPeriodSelection] => ,[topBarElements] => Array ([0] => Array ([0] => CoreHome,[1] => Πίνακας Οργάνων,[2] => Array ([module] => CoreHome,[action] => index)),[1] => Array ([0] => Widgetize,[1] => Widgets,[2] => Array ([module] => Widgetize,[action] => index)),[2] => Array ([0] => API,[1] => API,[2] => Array ([module] => API,[action] => listAllAPI)),[3] => Array ([0] => Feedback,[1] => Πείτε μας την γνώμη σας!,[2] => Array ([module] => Feedback,[action] => index,[keepThis] => true,[TB_iframe] => true,[height] => 400,[width] => 350),[3] => title="Πείτε μας την γνώμη σας!" class="thickbox")),[element] => Array ([0] => Feedback,[1] => Πείτε μας την γνώμη σας!,[2] => Array ([module] => Feedback,[action] => index,[keepThis] => true,[TB_iframe] => true,[height] => 400,[width] => 350),[3] => title="Πείτε μας την γνώμη σας!" class="thickbox")),[_smarty_vars] => ,[_sections] => Array (),[_foreach] => Array (),[_tag_stack] => Array (),[_conf_obj] => ,[_config] => Array ([0] => Array ([vars] => Array (),[files] => Array ()),[1] => Array ([vars] => Array (),[files] => Array ()),[2] => Array ([vars] => Array (),[files] => Array ())),[_smarty_md5] => f8d698aea36fcbead2b9d5359ffca76f,[_version] => 2.6.22,[_inclusion_depth] => 2,[_compile_id] => ,[_smarty_debug_id] => SMARTY_DEBUG,[_smarty_debug_info] => Array ([0] => Array ([type] => template,[filename] => CorePluginsAdmin/templates/manage.tpl,[depth] => 0),[1] => Array ([type] => template,[filename] => CoreAdminHome/templates/header.tpl,[depth] => 1),[2] => Array ([type] => template,[filename] => CoreHome/templates/js_global_variables.tpl,[depth] => 2,[exec_time] => 0.0011188983917236),[3] => Array ([type] => template,[filename] => CoreHome/templates/top_bar.tpl,[depth] => 2)),[_cache_info] => Array (),[_file_perms] => 420,[_dir_perms] => 505,[_reg_objects] => Array (),[_plugins] => Array ([modifier] => Array ([translate] => Array ([0] => smarty_modifier_translate,[1] => CorePluginsAdmin/templates/manage.tpl,[2] => 8,[3] => 1,[4] => 1),[urlRewriteWithParameters] => Array ([0] => smarty_modifier_urlRewriteWithParameters,[1] => CoreHome/templates/top_bar.tpl,[2] => 5,[3] => 1,[4] => 1)),[function] => Array ([postEvent] => Array ([0] => smarty_function_postEvent,[1] => CoreAdminHome/templates/header.tpl,[2] => 25,[3] => 1,[4] => 1),[assignTopBar] => Array ([0] => smarty_function_assignTopBar,[1] => CoreHome/templates/top_bar.tpl,[2] => 1,[3] => 1,[4] => 1)),[block] => Array (),[compiler] => Array (),[prefilter] => Array (),[postfilter] => Array (),[outputfilter] => Array ([trimwhitespace] => Array ([0] => smarty_outputfilter_trimwhitespace,[1] => ,[2] => ,[3] => 1,[4] => 1)),[resource] => Array (),[insert] => Array ()),[_cache_serials] => Array (),[_cache_include] => ,[_cache_including] => )) called at [ /piwik/tmp/templates_c/%%A5^A51^A51D6D8B%%top_bar.tpl.php:17]
#8 include( /piwik/tmp/templates_c/%%A5^A51^A51D6D8B%%top_bar.tpl.php) called at [ /piwik/libs/Smarty/Smarty.class.php:1870]
#9 Smarty->_smarty_include(Array ([smarty_include_tpl_file] => CoreHome/templates/top_bar.tpl,[smarty_include_vars] => Array ())) called at [ /piwik/tmp/templates_c/%%38^383^383EA889%%header.tpl.php:40]
#10 include( /piwik/tmp/templates_c/%%38^383^383EA889%%header.tpl.php) called at [ /piwik/libs/Smarty/Smarty.class.php:1870]
#11 Smarty->_smarty_include(Array ([smarty_include_tpl_file] => CoreAdminHome/templates/header.tpl,[smarty_include_vars] => Array ())) called at [ /piwik/tmp/templates_c/%%94^949^9498696C%%manage.tpl.php:8]
#12 include( /piwik/tmp/templates_c/%%94^949^9498696C%%manage.tpl.php) called at [ /piwik/libs/Smarty/Smarty.class.php:1264]
#13 Smarty->fetch(CorePluginsAdmin/templates/manage.tpl) called at [ /piwik/core/View.php:113]
#14 Piwik_View->render() called at [ /piwik/plugins/CorePluginsAdmin/Controller.php:37]
#15 Piwik_CorePluginsAdmin_Controller->index() called at [(null):0]
#16 call_user_func_array(Array ([0] => Piwik_CorePluginsAdmin_Controller Object ([] => CorePluginsAdmin,[] => 2009-03-12,[] => Piwik_Date Object ([] => 1236816000)),[1] => index), Array ()) called at [ /piwik/core/FrontController.php:147]
#17 Piwik_FrontController->dispatch() called at [ /piwik/index.php:51]
