Transitions load forever / don't work at all
(Christian) #1
Hi there,
I recently found out that loading transition data does not work at all on my piwik installation. It just says “Load transitions for”, but after 5min of waiting I don’t believe that there could be a result.
Can anyone help me out on this?
My System:
Shared Hosting
PHP-Version >= 5.3.3
Piwik version 2.11.0
All thins are ticked green on the “test settings” page
except for “LOAD DATA INFILE”
Thanks
Chris
(Matthieu Aubry) #2
Hi Chris
can you please create a bug report in: Issues · matomo-org/piwik · GitHub
and post any error you find in the server error log, or maybe some error in the javascript?
#3
I don’t know about your environment, but in the past I had difficulties if Piwik URL didn’t match the website in Transition reports.
I mean I was using internal URL to reach Piwik dasboard like this : http://stats.srv/
But the site I was checking was : http://www.mysite.com/
So by creating stats.mysite.com and reaching Transition report it then worked.
Dali
(Christian) #4
Hi!
I submitted a issue on github.
No JavaScript errors so far.
@Dali: I’m afraid I don’t understand exactly what you mean.
