Hi all,
I have a question about the Behaviour > Transitions.
Let’s say the user does the following navigation, using two tabs in his browser.
homepage - - > url 1- - - - - - - > url 11 - - - - - - - - > url 111
- - - - - - - > url 12 - - - - - - > url 121
I understand now that in the Log Visits report I have the time sequence, regardless of the tabs, i.e.:
homepage
url 1
url 12
url 11
url 121
url 111
But I don’t understand why in the Transitions report for url 12 I see something like:
From url 1 — url 12 — To url 11
because it’s impossible to reach url 12 directly from url 1, and it’s also impossible to reach url 11 from url 12.
I think that the Transitions report should show the actual navigation (I mean: using the ref
parameter), in that case:
From homepage — url 12 — To url 121
I think Matomo is not capable of manage such cases.
If you check the database, table log_link_visit_action
, can you check if the idaction_url_ref
/ idaction_name_ref
(there is a link to log_action
table) are updated following the referrer received by the server, or just reading the DB to check the last page view? I think it does the 2nd case…
I’ll check the database the way you suggested.
But I am wondering if there is a good reason for matomo to consider the last page view (as it seems in that case) and not the ref
parameter, that in my opinion would have given a more precise information about the user navigation.
By the way I have another question related to this.
Let’s say the user does the same navigation as described above (now I put also the times):
10:00 10:05 10:10 10:30
\ 10:07 10:12
In the Visit Log, I would see something like:
10:00 - homepage
10:05 - url 1
10:07 - url 12
10:10 - url 11
10:12 - url 121
10:30 - url 111
What would happen to the “Avg. time spent on page”?
I.e. in the actual navigation from url 1 to url 11 (10:05-10:10), the time spent on page url 1 should be 5 mins.
If matomo considers the page sequence in cronological order (url 1 → url 12) instead of the actual navigation (url 1 → url 11), that means that the time spent on page url 1 is 2 mins (10:05-10:07)?
Probably this would complicate the visit analysis, as this is not a common user behavior… Also, how display such complicated journey?
(You can create some feature request for this: https://github.com/matomo-org/matomo/issues/new?assignees=&labels=Enhancement&template=feature_request.md )
Good question!
As how I understood the Matomo engine (but I may be wrong), when the url 12
is received, Matomo would store the time spent on url 1
, and when the url 11
is received, Matomo would store the time spent on url 12
This must be experimented!
