I just set up Matomo to track a website and I am trying to make Matomo track users with cookies if they accept the cookies, without otherwise.
Following this i added _paq.push(['requireCookieConsent']); to my matomo script (which is executed on every page - is that how it’s supposed to be?).
I execute this in the callback function which is called each time the consent state changes:
if (_paq !== 'undefined') {
if (consent == true){
} else {
_paq.push(['forgetCookieConsentGiven'])
If the user accepts the cookies, then everything is working as expected, but if the user declines/doesn’t accept the cookies then no tracking data is received at all.
What am I missing? Why is the “tracking without cookies” not working as expected?
I am still not sure how is that supposed to make me track (without a cookie) a user who rejected/didn’t accept cookies: if the user rejects, both forgetConsentGiven and forgetCookieConsentGiven will be set.
In fact it is still not working, or at least it doesn’t work consistently. Most of the times it doesn’t work, and when it does, it only tracks the first visited page. I am sorry but I am really lost
How does the “forgetConsentGiven” and the “forgetCookieConsentGiven” look like in your case? Is it a simple button? You can make it so:
<button onclick="_paq.push(['forgetConsentGiven']);_paq.push(['forgetCookieConsentGiven']);">Forget Consent Given</button>
In this case forget both, because “CookieConsentGiven” needs “ConsentGiven”.
<button onclick="_paq.push(['forgetCookieConsentGiven']);">Forget Cookie Consent Given</button>
In this case, only the “CookieConsentGiven” is forget and the “ConsentGiven” is kept.
I am using Klaro! as CMP.
When the user accepts or declines, both consentGiven and cookieConsentGiven are set.
My goal is to make it so that if the user doesn’t accept or declines, the tracking is still active, just without cookies. From what I understand this should be possible, correct me if in wrong.
I thought and expect that if cookieConsentGiven is set, then cookies will be used for tracking, if it’s not set, then the tracking will take place without cookies.
OK, that is not a matter of matomo, but Klaro! You can tell your question about that in the Klaro! Github Issues: https://github.com/kiprotect/klaro/issues
… but, there are no answers by the most Issues.
But the buttons work well: the consent is set correctly on accept/decline and the callback is called accordingly… Is there anything else I need to set to enable tracking without cookies when the user doesn’t accept cookies?
