Tracking does not work on a new installation
#1
We have installed the latest version of Piwik on IIS and added 5 sites and added the tracking code to each site, but none of the site visits are being logged. We have set up Piwik on the root of https://stats.spydus.co.uk and are using the tracking code below on the example URL below:
Please can somebody give me some pointers on how to get this working. I have been through the help section on the issue and no joy.
https://richmond.spydus.co.uk/cgi-bin/spydus.exe/MSGTRN/OPAC/HOME
    var _paq = _paq || [];
    (function(){
    var u = (("https:" == document.location.protocol) ? 'https://stats.spydus.co.uk/' : 'http://stats.spydus.co.uk/');
    _paq.push(['setSiteId', 3]);
    _paq.push(['setTrackerUrl', u + 'piwik.php']);
    _paq.push(['trackPageView']);
    var d = document, g = d.createElement('script'), s = d.getElementsByTagName('script')[0];
    g.type = 'text/javascript';
    g.defer = true;
    g.async = true;
    g.src = u + 'piwik.js';
    s.parentNode.insertBefore(g, s);
  </script><!-- End Piwik Code -->
#2
You changed the tracking code:
should be
var u=((“https:” == document.location.protocol) ? “https” : “http” ) + “://stats.spydus.co.uk/”;
or if you don’t want to test for the protocol
var u=(“https://stats.spydus.co.uk/” );
#3
Thanks for getting back to me Steve. I changed the code to the above but the logging is still not appearing. Can you help?
I have added the tracking code below to www.dustdiva.co.uk because it’s quicker to change and test. It is sending the request to https://stats.spydus.co.uk (See request at the bottom of this post) but no data is being reported. Any ideas what’s wrong?
/piwik.php?action_name=Dust%20Diva%20-%20North%20Devon%20Cleaning%20Services%20-%20North%20Devon%2C%20Umberleigh%2C%20Barnstaple%2C%20Bideford&idsite=6&rec=1&r=461771&h=9&m=14&s=9&url=http%3A%2F%2Fwww.dustdiva.co.uk%2F&_id=30279c312eadddee&_idts=1407748237&_idvc=2&_idn=0&_refts=0&_viewts=1407748599&pdf=1&qt=0&realp=0&wma=0&dir=0&fla=1&java=1&gears=0&ag=1&cookie=1&res=1680x1050&gt_ms=1700
#4
I have run firebug on the tracking request and can see that the tracking isn’t working because of the following error. Anyone know how to fix this?
Error query: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘location_provider’ in ‘field list’ In query: INSERT INTO piwik_log_visit (idsite, visitor_localtime, idvisitor, visitor_returning, visitor_count_visits, visitor_days_since_last, visitor_days_since_order, visitor_days_since_first, visit_first_action_time, visit_last_action_time, visit_entry_idaction_url, visit_entry_idaction_name, visit_exit_idaction_url, visit_exit_idaction_name, visit_total_actions, visit_total_searches, visit_total_events, visit_total_time, visit_goal_buyer, referer_type, referer_name, referer_url, referer_keyword, config_id, config_os, config_os_version, config_browser_name, config_browser_version, config_resolution, config_device_type, config_device_model, config_device_brand, config_pdf, config_flash, config_java, config_director, config_quicktime, config_realplayer, config_windowsmedia, config_gears, config_silverlight, config_cookie, location_ip, location_browser_lang, visit_goal_converted, location_provider, location_country) VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?) Parameters: array ( 0 => 6, 1 => ‘10:52:10’, 2 => ‘�5��r’, 3 => 1, 4 => 2, 5 => 5, 6 => 0, 7 => 5, 8 => ‘2014-08-13 09:52:44’, 9 => ‘2014-08-13 09:52:44’, 10 => 5, 11 => 4, 12 => 5, 13 => 4, 14 => 1, 15 => 0, 16 => 0, 17 => 0, 18 => 0, 19 => 1, 20 => false, 21 => ‘’, 22 => false, 23 => ‘�F �r=��’, 24 => ‘WI7’, 25 => ‘7’, 26 => ‘FF’, 27 => ‘31.0’, 28 => ‘1344x840’, 29 => 0, 30 => ‘’, 31 => ‘’, 32 => 1, 33 => 1, 34 => 0, 35 => 0, 36 => 0, 37 => 0, 38 => 0, 39 => 0, 40 => 1, 41 => 1, 42 => ’ SD�’, 43 => ‘en-us,en’, 44 => 0, 45 => ‘Ip’, 46 => ‘us’, )
Backtrace:
#0 C:\inetpub\wwwroot\Piwik\core\Tracker\Visit.php(444): Piwik\Tracker\Db\Pdo\Mysql->query(‘INSERT INTO piw…’, Array)
#1 C:\inetpub\wwwroot\Piwik\core\Tracker\Visit.php(325): Piwik\Tracker\Visit->insertNewVisit(Array)
#2 C:\inetpub\wwwroot\Piwik\core\Tracker\Visit.php(206): Piwik\Tracker\Visit->handleNewVisit(Object(Piwik\Tracker\ActionPageview), false)
#3 C:\inetpub\wwwroot\Piwik\core\Tracker.php(872): Piwik\Tracker\Visit->handle()
#4 C:\inetpub\wwwroot\Piwik\core\Tracker.php(242): Piwik\Tracker->trackRequest(Array, NULL)
#5 C:\inetpub\wwwroot\Piwik\piwik.php(121): Piwik\Tracker->main()
#6 {main}
#5
If that column is missing, your table is not setup correctly. If you haven’t collected any data, you might want to try reinstalling.
#6
Thanks sneakyllama, unsinstalling and reinstalling the latest version has sorted it. Tracking is working now :slight_smile:
(Matthieu Aubry) #7
Which version of Piwik do you use?
Could you try upgrade to 2.5.0-rc1 published just today?
If you stil have the issue after upgrading please disable the Provider plugin.
#8
Have upgraded to 2.4 and that has sorted it.
