@Vasilis Lourdas: I thought I can see the tracking already after 10seconds… I don’t believe I need to wait for 24 hours to see tracking!!
@PeterV: Correct… I was testing a lot in the hope something was working and forgot to put it back were it belongs. Anyway I put it before the /body again…
As I recall, by default Piwik does not show the visits for the current day. However, if you set the date range to include the current day, it does show them.
In the dashboard I see: Date Range: 2014-08-31… Then I think today is the day I’m looking too…is that what you mean? I can’t see there any track information
I just visited your page and Piwik script executed correctly, but it’s being blocked with error 403 forbidden, check in Settings> General Settings under Trusted Piwik Hostname if your Piwik host is added there.
Regards,
Michal
The HTTP request for the Piwik tracking code is initiated with JS. So you must use the console window in Firefox (press F12), Chrome, etc. to see the actual request and its response code. The url you display above has nothing to do with Piwik.
I really do not know were I need to search for the 403 error. I is given “forbidden” or no access…but the url http://www.xxxxx.nl/piwik/piwik.php is not blocking anything…
