i’m not sure about informations i found in the documentation.
I have a website with matomo on it, everything is fine.
But now we would like to track visitors came on our homepage with specific url parameter. For example people can arrived on: https://example.com/
or on https://example.com/MYPARAMETER
Then, if second people visit the rest of the website, the parameter disappear from url, there is only a session variable that allows me to know the pages visited.
But on matomo i can’t see the route of the pages visited by people who arrived via the url parameter.
Do you think it’s possible with matomo ?
Do i need to put tu parameter in each URL visited ?
Can i bind my session’s variable to matomo ?
Hello Alex, the problem sounds not simple. questions:
In the most cases (modern) CMS websites have different URLs for different pages. The URL is used to detect which content is to be delivered over the virtual folder name. example.com = Startpage example.com/about = About us page example.com/imp = Imprint
Default, matomo track about and imp and displayed it in the statistiks. The startpage is displayed as /index. In the statistik “Page Title”, not this virtual folder name is displayed, but the HTML <title>.
Question: How is your website structured?
When you have a example.com/MYPARAMETER, the MYPARAMETER is displayed in matomo. Is it the same in your matomo?
Another idea: You will track users special, that comes in over the example.com/MYPARAMETER?
Special tracking of this user is possible with visitor id / user id.
Display the stats over this user is possible with segmentation.
Create a segment:
Click the button “All visits” above.
Click the green button “Add new segment”.
Select
“Behavior” → Entry Page URL.
Is example.com/MYPARAMETER
Click “TEST” or “Save & APPLY”.
By “Save & APPLY” you see in the dashboard only the visits from this users. You can change it to “Visit all” over the same named button.
It depends on if you want just to separate visitors arriving on page example.com/MYPARAMETER from another users, or if you want to separate MYPARAMETER?1 from MYPARAMETER?2
(Note: your usage of parameters is a little bit strange, i suggest you use query string)
