The opt-out clause appearing on the website contains the information “This opt out feature requires JavaScript”. I don’t know what WordPress plugin is responsible for this. Please help as I turn plugins off and on but it doesn’t work. Matomo diagnostic panel shows some problem, but I can’t locate it. Thank you in advance for your help.
- Matomo Plugin Version: 5.0.5
- Config exists and is writable.: Yes (“$abs_path/wp-content/uploads/matomo/config/config.ini.php” )
- JS Tracker exists and is writable.: Yes (“$abs_path/wp-content/uploads/matomo/matomo.js” )
- Plugin directories: Yes ([{“pluginsPathAbsolute”:“$abs_path/wp-content/plugins/matomo/plugins”,“webrootDirRelativeToMatomo”:“…/plugins”}])
- Tmp directory writable: Yes ($abs_path/wp-content/cache/matomo)
- Matomo Version: 5.0.2
- Matomo Blog idSite: 1
- Matomo Install Version: 5.0.5 (Install date: 2024-04-22 11:25:55)
- Upgrades outstanding: No
- Upgrade in progress: No
Endpoints
- Matomo JavaScript Tracker URL: ($site_url/wp-content/uploads/matomo/matomo.js)
- Matomo JavaScript Tracker - WP Rest API: ($site_url/wp-json/matomo/v1/hit/)
- Matomo HTTP Tracking API: ($site_url/wp-content/plugins/matomo/app/matomo.php)
- Matomo HTTP Tracking API - WP Rest API: ($site_url/wp-json/matomo/v1/hit/)
Crons
- Server time: 2024-04-22 18:41:54
- Blog time: 2024-04-22 18:41:54 (Below dates are shown in blog timezone)
- Sync users & sites: Next run: 2024-04-23 11:27:03 (16 godzin 45 min) ( Last started: 2024-04-22 11:27:19 (-7 godzin 14 min). Last ended: 2024-04-22 11:27:19 (-7 godzin 14 min). Interval: daily)
- Archive: Next run: 2024-04-22 19:26:00 (44 min 6s) ( Last started: 2024-04-22 18:26:22 (-15 min 32s). Last ended: 2024-04-22 18:26:26 (-15 min 28s). Interval: hourly)
- Update GeoIP DB: Next run: 2024-05-22 11:27:02 (29 dni 16 godzin) ( Last started: 2024-04-22 11:27:17 (-7 godzin 14 min). Last ended: 2024-04-22 11:27:19 (-7 godzin 14 min). Interval: matomo_monthly)
Mandatory checks
- wersja PHP >= 7.2.5: ok
- PDO rozszerzenie: ok
- PDO\MYSQL rozszerzenie: ok
- MYSQLI rozszerzenie: ok
- Pozostałe wymagane rozszerzenia: ok
- Wymagane funkcje: ok
- Wymagana konfiguracja PHP (php.ini): ok
- Katalogi z prawem do zapisu: ok
- Katalogi z uprawnieniami do zapisu dla Menadżer Tagów: ok
Optional checks
- 64-bit PHP Binary: ok
- Status śledzenia: ok
- Limit pamięci: ok
- Strefa czasowa: ok
- Otwórz URL: ok
- GD > 2.x + Freetype (graphics): ok
- Pozostałe rozszerzenia: ok
- Pozostałe funkcje: ok
- System plików: ok
- Last Successful Archiving Completion: ok
- Możliwości bazy danych: ok
- Max Packet Size: ok
- Geolokalizacja: ok
- Aktualizacja przez HTTPS: ok
- Mobile Messaging SMS Provider: ok
- Supports Async Archiving: Yes
- Async Archiving Disabled in Setting: No
- Location provider ID: geoip2php
- Location provider available: Yes
- Location provider working: Yes
- Had visit in last 5 days: Yes
- Matomo URL: Yes ($site_url/wp-content/plugins/matomo/app/)
Matomo Settings
- Track mode: default
- Track ecommerce: Yes
- Track codeposition: footer
- Track api endpoint: default
- Track js endpoint: default
- Version history: 5.0.5
- Core version: 5.0.2
- Last tracking settings update: 1713785348
- Last settings update: 1713785348
Logs
- None:
WordPress
- Home URL: $site_url
- Site URL: $site_url
- WordPress Version: 6.5.2
- Number of blogs: 1
- Multisite Enabled: No
- Network Enabled: No
- WP_DEBUG: No
- WP_DEBUG_DISPLAY: Yes
- WP_DEBUG_LOG: No
- DISABLE_WP_CRON: -
- FORCE_SSL_ADMIN: Yes
- WP_CACHE: No
- CONCATENATE_SCRIPTS: -
- COMPRESS_SCRIPTS: -
- COMPRESS_CSS: -
- ENFORCE_GZIP: -
- WP_LOCAL_DEV: -
- WP_CONTENT_URL: $site_url/wp-content
- WP_CONTENT_DIR: $abs_path/wp-content
- UPLOADS: wp-content/uploads
- BLOGUPLOADDIR: -
- DIEONDBERROR: -
- WPLANG: -
- ALTERNATE_WP_CRON: -
- WP_CRON_LOCK_TIMEOUT: 60
- WP_DISABLE_FATAL_ERROR_HANDLER: -
- MATOMO_SUPPORT_ASYNC_ARCHIVING: -
- MATOMO_ENABLE_TAG_MANAGER: -
- MATOMO_SUPPRESS_DB_ERRORS: -
- MATOMO_ENABLE_AUTO_UPGRADE: -
- MATOMO_DEBUG: -
- MATOMO_SAFE_MODE: -
- MATOMO_GLOBAL_UPLOAD_DIR: -
- MATOMO_LOGIN_REDIRECT: -
- Permalink Structure: /%postname%/
- Possibly uses symlink: No
- Upload base url: $site_url/wp-content/uploads
- Upload base dir: $abs_path/wp-content/uploads
- Upload url: $site_url/wp-content/uploads/2024/04
- Custom upload_url_path:
- Compatible content directory: Yes
- WP_Filesystem Initialized: Yes
WordPress Plugins
MU Plugins
- installatron_hide_status_test.php:
Plugins
- All in One SEO: 4.6.1.1
- Autoptimize: 3.1.11
- Classic Editor: 1.6.3
- CookieYes | GDPR Cookie Consent: 3.2.2
- Disable Comments: 2.4.6
- Dublin Core Metadata: 0.99
- Easy Social Icons: 3.2.6
- Flexy Breadcrumb: 1.2.1
- Gallery Lightbox Lite: 1.0.0.39
- Gutenberg: 18.1.2
- Lazy Load - Optimize Images: 2.3.6
- Limit Login Attempts Reloaded: 2.26.8
- Matomo Analytics - Ethical Stats. Powerful Insights.: 5.0.5
- Open Graph: 1.11.2
- Preloader: 1.0.9
- Rename wp-login.php: 2.6.0
- Swap Google Fonts Display: 1.1.1
- Web Stories: 1.36.0
- Widget Contact Now: 1.0.1
- Wordfence Security: 7.11.5 (Network enabled)
- WP Fastest Cache: 1.2.5
- WP SEO Structured Data Schema: 2.7.10
- WP Super Minify: 1.6
- Active Plugins: 22 (all-in-one-seo-pack:4.6.1.1 autoptimize:3.1.11 classic-editor:1.6.3 cookie-law-info:3.2.2 disable-comments:2.4.6 dublin-core-metadata:0.99 easy-social-icons:3.2.6 flexy-breadcrumb:1.2.1 gallery-lightbox-slider:1.0.0.39 limit-login-attempts-reloaded:2.26.8 matomo:5.0.5 opengraph:1.11.2 rename-wp-login:2.6.0 rocket-lazy-load:2.3.6 swap-google-font-display:1.1.1 the-preloader:1.0.9 web-stories:1.36.0 widget-contact-now:1.0.1 wordfence:7.11.5 wp-fastest-cache:1.2.5 wp-seo-structured-data-schema:2.7.10 wp-super-minify:1.6)
- Theme: creativ-agency (creativ-agency)
Server
- Server Info: Apache/2
- Apache AddHandler support: Supported
- PHP OS: Linux
- PHP Version: 8.1.27
- PHP SAPI: fpm-fcgi
- PHP Binary Name: /usr/local/php81/sbin/php-fpm81
- PHP Maxmind DB extension: Not loaded
- PHP Error Reporting: 4437 After bootstrap: 4437
- PHP Found Binary: /usr/local/bin/php -q
- Timezone: UTC
- WP timezone: +00:00
- Locale: pl_PL
- User Locale: pl_PL
- Memory Limit: 256M (At least 128MB recommended. Depending on your traffic 256MB or more may be needed.)
- WP Memory Limit: 40M
- WP Max Memory Limit: 256M
- Timezone version: 2023.3
- Time: 1713811315
- Max Execution Time: 120
- Max Post Size: 256M
- Max Upload Size: 268435456
- Max Input Vars: 10000
- Disabled PHP functions: No
- zlib.output_compression is off: Yes
- Curl Version: 7.64.0, OpenSSL/1.1.1n
- Suhosin installed: No
PHP cli
- PHP cli Version: 8.1.27
- MySQLi support: ok
- PHP CLI configuration: Configured correctly
Database
- MySQL Version: 10.6.16
- Mysqli Connect: Yes
- Force MySQL over Mysqli: No
- DB Prefix: wp_
- DB CHARSET: utf8
- DB COLLATE:
- SHOW ERRORS: No
- SUPPRESS ERRORS: No
- Uses Socket: No
- Uses IPv6: No
- Matomo tables found: 50
- DB tables exist: Yes
- Matomo users found: 1
- Matomo sites found: 1
- Required permissions: OK
Browser
- Browser: (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/124.0.0.0 Safari/537.36)
- Language: pl-pl,pl,en-gb,en,en-us,ru
