I´m using the word press Matomo plugin with Word Press 6.6.2 and plugin version 5.1.5. I get the following error in the dashboard. The string General_Confirm was not loaded in javascript. Make sure it is added in the Translate.getClientSideTranslationKeys hook.
This is when I try to change settings (not in the word press dashboard). It than says, that the passoword is not correct. But it is (WordPress password).
Would be great if you could help me out.
