Hello friends, could you give me a clue about the error that my piwik serer gives?
Hola amigos, podrian darme una pista sobre el error que da mi seridor piwik
log error
[Mon Apr 09 16:16:37.701717 2018] [:error] [pid 724] [client 10.16.147.8:57656] Error in Piwik: syntax error, unexpected ''lic' (T_ENCAPSED_AND_WHITESPACE), expecting ')', referer:
https://stats.arba.gov.ar/index.php
[Mon Apr 09 16:19:43.556402 2018] [:error] [pid 727] [client 10.16.147.8:57688] Error in Piwik: syntax error, unexpected ''lic' (T_ENCAPSED_AND_WHITESPACE), expecting ')'
Lukas
(Lukas Winkler)
April 10, 2018, 6:15am
#2
The error sounds like a PHP syntax error, which shouldn’t happen normally. Can you check your php error_log for more information? It should show you the file and line where the error occurs. Maybe it is a plugin causing it?
Thanks People, the solutions eliminating the temporary files of piwik
