When trying to update our Piwik install to 1.8.4 we get the following error when updating the database
Error trying to execute the query ’ UPDATE
piwik_log_link_visit_action
AS link
LEFT JOIN
piwik_log_action_duplicates
AS duplicates_idaction_url
ON link.idaction_url = duplicates_idaction_url.before
SET
link.idaction_url = duplicates_idaction_url.after
WHERE
duplicates_idaction_url.after IS NOT NULL;
The error was: SQLSTATE[42000]: Syntax error or access violation: 1104 The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET MAX_JOIN_SIZE=# if the SELECT is okay
Our hosting company has said we need to run the following before the update ‘SET SQL_BIG_SELECTS=1’
How would i go about doing this on Piwik? This is shared hosting with no access to SSH
Thanks
