I’m having grief with IE7 (unfortunatley my clients use it, so don’t have any choice!).
Any widget set to display sparklines is rendered incorrectly; I’ll attach a screendump.
Anyone else seeing this behaviour from IE, and anyone got any suggestions how to fix it? Which stylesheet or script is used to render these widgets - a quick glance at the HTML they generate shows a huge list of CSS and JS links…
No, results are only out IE. Not sure what you mean by “rendered on server” - it’s all HTML that’s produced, not a server-side construct like a swf or a single image, so layout is a surely a function of CSS or any DOM-maniuplating JS which is running in the IFRAME?
Widget - on dashboard and in my own pages where I’m using the widgets. It should be something we can fixup with a CSS or JS hack, but I’m not sure where best to do that - there’s a healthy number of CSS and JS files linked into the widget’s IFRAME! I was also curious as to whether others have seen this behaviour - it wouldn’t be the first time I’ve had to deal with IE weirdness which is actually hard to replicate on another PC!
