I don’t have access to setup a “real” cronjob, I did the archiving always via webcron. But now - when testing the webcron via browser I get an error message I don’t understand:
You must specify the Super User token_auth as a parameter to this script, eg. ?token_auth=XYZ if you wish to run this script through the browser.
Well that is what I do: The URL I’m calling seems to be right:
… and 1234567890 is the API Key from my super users account. So what to change? Small side question: On the API page the key is given with a leading ‘&’:
&token_auth=1234567890
, NOT with a ‘?’, but it makes no difference, the error occurs anyway.
As workaround I tried the archiving via browser, but that seems not to work too: No data in the graphs for the most sites, but I can see the visitors log is filled with data.
Can anybody point me in the right direction?
My setup:
Piwik 2.9.1
shared hosting enviroment
All green in Settings -> Systemcheck
But: No LOAD DATA INFILE at all (I’ve turned it off via config)
150 low traffic sites are tracked.
30 sites get data in the graphs, the rest stays empty.
It’s strange the archive.php web cron does not load with your Super User token. I just tested it and it works fine for me. Could you try again or with a nother super user token auth?
Hi! Thanks for taking the time to look into this.
I created a new user and gave hime SU rights. Then I logged into Piwik to find the new token for that user. After that I tried to run the webcron via browser, but I still get the same message.
If you want to look for yourself I could send you a PM with the token and the link. If that would help…
I’ve setup a cronjob at www.easycron.com and tested it (manually).
Though the easycron system tells me that the cronjob had “succeeded”,
Start Time: 2014-11-24 07:11:16
End Time: 2014-11-24 07:11:16
Connect Time (second): 0.111495
Total Time (second): 0.399507
HTTP Code: 200
Status: Succeeded
the reply of it is just the same:
HTTP/1.1 200 OK
Date: Mon, 24 Nov 2014 07:06:19 GMT
Server: Apache/2.2.22 (Debian)
Vary: Accept-Encoding
Transfer-Encoding: chunked
Content-Type: text/html
<b>You must specify the Super User token_auth as a parameter to this script, eg. <code>?token_auth=XYZ</code> if you wish to run this script through the browser. </b><br>
However it is recommended to run it <a href="....">via cron in the command line</a>, since it can take a long time to run.<br/>
In a shell, execute for example the following to trigger archiving on the local Piwik server:<br/>
<code>$ /path/to/php /path/to/piwik/console core:archive --url=http://your-website.org/path/to/piwik/</code>
It is not the normal reply, why dont you try to load it via HTTP directly? it should load for you the core:archive output. If it really does not work fory ou with Piwik 2.9.1 then please create an issue on Issues · matomo-org/piwik · GitHub
Thanks Matt!
Please specify what it means when you write
I don’t understand that because I thought calling the URL via browser is in fact loading via http. What else can I try? Sorry, I don’t have a clue right now.
Thanks,
Chris
can you please email me at matt @piwik a link to this forum post, as well as the URL with your token_auth ? (I will not share it with anyone of course and you can change it afterwards)
