I am using PIWIK 2.8.3 with PHP version 5.3.3-7+squeeze22.
When I click on “Settings” (more precisely, this URL: …/piwik/index.php?module=UsersManager&action=userSettings&idSite=1&period=day&date=today), only a blank page is shown. (This happens on Chrome; when I use IE, a HTTP 500 error is shown.)
I am not good with PHP, but I traced the problem back to a function “getMenu()”. It is called at several places, for example in “setBasicVariablesAdminView” of ControllerAdmin.php, and anytime it is called, the program gets caught in some kind of infinity loop and never gets back.
I was not able to find the implementation of that function (or rather I found many implementations and couldn’t figure out the right one), so my debugging process stopped here.
Any suggestions?
Thanks and best regards
Lukas
PS. The “Marketplace” doesn’t work either showing the same symptoms. Didn’t try to debug here so far.
Ok, I looked into it. The errorlog does not seem to have anything relevant (just me, misspelling my password ):
[Tue Oct 28 13:07:45 2014] [error] [client 198.27.70.] File does not exist: /home/ws/aifb-web-0008/info2.aifb.kit.edu/htdocs/wp/beispiel-seite
[Tue Oct 28 13:19:25 2014] [error] [client 198.27.70.] File does not exist: /home/ws/aifb-web-0008/info2.aifb.kit.edu/htdocs/wp/beispiel-seite
[Tue Oct 28 15:30:51 2014] [error] [client 141.3.194.] user aifb-web-0008: authentication failure for “/global-cgi-bin/myerrorlog”: Password Mismatch
[Tue Oct 28 15:31:15 2014] [error] [client 141.3.194.] user aifb-web-0008: authentication failure for “/global-cgi-bin/myerrorlog”: Password Mismatch
[Tue Oct 28 15:31:27 2014] [error] [client 141.3.194.*] user aifb-web-0008: authentication failure for “/global-cgi-bin/myerrorlog”: Password Mismatch
The accesslog shows these entries when I try to access the properties page (or maybe just the last one… I’m not sure):
I solved it. It was a plugin causing the problem. When I removed it, all worked fine!
Thanks, Matt, for the hint of checking the log files - another log file contained the following message:
[28-Oct-2014 14:44:27] PHP Parse error: syntax error, unexpected ‘[’ in
/home/hard/sccfs-web/aifb-web-0008/info2.aifb.kit.edu/htdocs/piwik/pl
ugins/LdapVisitorInfo/LdapVisitorInfo.php on line 43
Thank you SO MUCH lukaskoenig, I just had the same problem after an update.
I didn’t have any clue since I do not have access to all the logs from my webhost, but indeed I didn’t think about plugins I downloaded in the past (and didn’t even activate!), and since I could not access the Settings page, I just deleted everything inside the plugins/ folder and then reuploaded the plugins/ folder inside a fresh vanilla piwik.zip archive.
And it worked! I now have access back to my settings page and everything runs smoothly.
This is ridiculous, of course, the first problem source of any extensible application are the plugins, and this is the first place to tinkle with when something goes wrong.
However, this was written nowhere in the documentation. I really think the developpers should add this advice (to backup the plugins/ folder somewhere else, wipe it up, and reupload a standard plugins/ folder from a piwik.zip archive) to the FAQ here:
Another thing: it should be noted in the same FAQ entry I cited that most often, blank pages are produced because servers can’t show error messages. It could be advised to enable PHP errors in order to better diagnose those issues.
