INIT
Querying Piwik API at: http://piwik.example.org/index.php
Running Piwik 1.10.1 as Super User: Marbot
ERROR: The Piwik URL http://piwik.example.org/index.php does not seem to be pointing to a Piwik server. Response was '<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<HTML><HEAD>
<TITLE>401 Authorization Required</TITLE>
</HEAD><BODY>
<H1>Authorization Required</H1>
This server could not verify that you
are authorized to access the document
requested. Either you supplied the wrong
credentials (e.g., bad password), or your
browser doesn't understand how to supply
the credentials required.<P>
</BODY></HTML>'.
How do I provide the credentials? Help is most welcome. Cheers
Thank you for the tip. Just by reading the instructions on apache.org I would believe that this should work. However, reality is different. This setting allows everybody to access the login page for Piwik.
Sadly, this does not work. I still get the authorisation error from cron. I cannot really believe that I should be the only one who is trying to set up piwik with access authorisation. However, it seems to be like it.
