I’m trying to run the archiving command but every time I run it, there’s no output. This is the command I’m running.
sudo su tb-matomo-admin -s /bin/bash -c "/opt/bitnami/php/bin/php /opt/bitnami/apps/matomo/htdocs/core core:archive --url=https://mywebsite.com"
‘/opt/bitnami/php/bin/php’ is the output of ‘which php’
‘/opt/bitnami/apps/matomo/htdocs/core’ is the directory where the ‘Console.php’ file exists.
As stated, this command gives no output after running. I’m also curious where I should actually save my file so that it get’s executed properly? The bitnami file structure doesn’t seem compatible with the current documentation from Matomo?
That does create a log file, but it’s empty. There doesn’t seem to be a /etc/crontab, but there is a /etc/cron.daily/etc/cron.hourly etc. that I have access to.
Bitnami made an app that automates the installation of Matomo on an Azure VM. Apparently with a strange file structure.
