I have written 2 custom plugins that integrate location information and visitor photos to the live feeds using the hook “Live.getExtraVisitorDetails” for an internal Piwik server. This all works perfectly but it doesn’t seem like the Live.* hooks are saved into the database. If we run a report the information is not there, but it does display on the live widgets.
I looked at the docs but couldn’t find a similar hook that wasn’t for Live data. I have also come across dimensions but that seems like it’s more for custom properties and not for updating existing ones, correct me if I’m wrong?
The fields we update on the visitor data are:
- visitorAvatar
- languageCode
- latitude
- longitude
- city
Is there a way to update this information for visitors that would be saved/archived to the database? Thanks!
